Headlamp bulb replacement
Old Dec 5, 2020 | 10:52 AM
Tibbetts's Avatar
Default Headlamp bulb replacement
The main headlamp beam is inoperative and needs to be replaced. Can someone explain the procedure?
Old Dec 5, 2020 | 11:58 AM
Greg in France's Avatar
Yes, if you tell us what model and year of car, and if it has twin or one-piece headlights.
Old Dec 5, 2020 | 12:06 PM
Tibbetts's Avatar
1992 XJS single headlight.
Old Dec 5, 2020 | 12:32 PM
Vee's Avatar
Vee
You probably have a “trap door” in the wheel well. Open that up and peek inside. Should be more obvious then?
Old Dec 5, 2020 | 02:49 PM
If, as Vee says, you do not have the trap door, then you have to remove the surround and then remove the light unit. If you do have the trap door (usually a round removable panel set into the wheelarch baffle) you can reach in and get at the back of the unit without needing to remove it.
Old Dec 6, 2020 | 08:02 AM
Vee's Avatar
Vee
The facelift trap doors are not round. They are a rectangular-ish shape?
Old Dec 6, 2020 | 07:13 PM
Dopplebocker's Avatar
Default It's "Round"
Item #8 is the "door" used to access your 1992 XJS headlight.
Old Dec 6, 2020 | 07:53 PM
Tibbetts's Avatar
Thanks for the input. This door in your illustration is exactly what I have. I am going to replace both bulbs and plan to remove road wheels to facilitate accessibility.
Best regards,
Tibbetts
Old Dec 6, 2020 | 09:13 PM
Vee's Avatar
Vee
Best regards,
Tibbetts
if you just turn the wheel “in”, it’ll give you more than enough room.
You’ll just have to turn the wheel the other way when you replace the headlight on the other side.
Old Dec 14, 2020 | 09:44 PM
afterburner1's Avatar
LED bulbs are really bright, but the problem i found with them is the bulb and the plastic lens cover are incompatiable. The problem is the location of the filiments in the LED; They are not compatical with the lens focus. I would like to hear from anyone that has overcome this problem
Harry Peter Rose
Canada
Aug 13, 2016 04:08 PM
XKGuy
Jan 16, 2013 11:37 PM
bulkmail07
Sep 28, 2011 11:59 AM
Jessy
Feb 27, 2009 02:38 PM
