LED Bulbs
Old Oct 14, 2015 | 11:05 PM
workworkwork's Avatar
Default LED Bulbs
V12 Performance sells an LED bulb replacement. Has anyone used this? Is it any good. Is there a better LED bulb out there to buy?
Old Oct 15, 2015 | 03:36 AM
user 652867429824's Avatar
from what I understand from past posts on this, you can find them cheaper, I got mine on Ebay (been 2 yrs ago so don't remember were), but do a search there and a google search. There are places you can find the small bulbs for the center dash switches. If I find the places I got mine I will pass it on
found one place https://www.superbrightleds.com/cat/...NG+-+Car+Bulbs
Old Oct 15, 2015 | 10:04 AM
xjsman89's Avatar
Default LED Bulbs
Daverb has it right, I have purchased many products from super bright LEDs and have always been happy with them. I've used their 194 bulbs in my Olds and their "make your own size strips" at work on a few work tables, machines, etc. I recommend them.
Old Oct 15, 2015 | 11:00 AM
I ordered some of these (not the collections) about a year ago and was disappointed.
I found better product, better selections at better prices at LEDlight.com.
Old Oct 15, 2015 | 08:21 PM
Looked over the superbrightled bulb site. There are a lot of these types of bulbs. I will have to measure these things to match them up. But, they are less costly. Thanks for the information.
Old Oct 15, 2015 | 08:40 PM
Dave1109971's Avatar
if you do a search on the forum you'll find some threads regards this and many of us have put up what we bought from them for our interiors etc.
https://www.jaguarforums.com/forum/x...ements-150215/
https://www.jaguarforums.com/forum/x...nt-swap-89533/
https://www.jaguarforums.com/forum/x...lights-124049/
Old Oct 17, 2015 | 05:08 AM
scottpeterd's Avatar
Before you order with Brian, please check out the threads here on Brian and V12 Performance. Too many of us here have had 'issues' with him and have lost money.
I have recently lost over $400 with him.
Just a heads up
Old Dec 5, 2015 | 10:44 AM
van883's Avatar
I just installed some LEDs from Quicksilver Automotive I can now see my speedo!
Old Dec 6, 2015 | 02:15 AM
Greg in France's Avatar
Which model do you have please? And did they plug in Ok like the originals, or did you have to take the pack to bits first (rear white cover off etc etc)?
Greg
Old Dec 6, 2015 | 01:53 PM
van883's Avatar
I have a 1989 pre facelift 3.6
I bought 5 green LEDs rather than the big kit which contains all the warning light bulbs as well.
I hope this helps.
Van
Old Dec 7, 2015 | 01:47 AM
I hope this helps.
Van
Van
Did they plug straight into the back of the pack like the old bulbs?
Greg
Old Dec 7, 2015 | 06:00 AM
Greg the leds i bought ftom superbrightled plugged straight in no hassles at all.
Old Dec 7, 2015 | 03:58 PM
van883's Avatar
Greg, they plugged straight in with no trouble.
Van
Old Dec 7, 2015 | 11:07 PM
Forcedair1's Avatar
Since we're on the subject, is there such a thing as a full cross reference listing of all the XJS lamps vs their LED quivalents, including their specific location/application? I still don't have a single LED on my kitty, other than the floor illumination set up. I really need to start thinking about going LED's both, interior and exterior, but I don't know where to start.
Thanks in advance,
Old Dec 11, 2015 | 11:58 AM
scarbro2011's Avatar
I replaced the stop lights and turn signal lamps with LED equivalents about
4 years ago.
I had to use a load resistor because the 1994 used a flasher relay. Without
the load resistor the flasher does a really fast blinking cycle.
I still get a lamp out indication on the console with and without the
load resistor. But the lamps work great and there is a reduced load on the
battery and alternator.
I believe I got my lamps from SuperBrightLeds also.
P O R - Press On Regardless !
JoshuaKM1
Apr 27, 2019 04:04 AM
scardini1
Jun 15, 2016 11:00 PM
Philurusso
Dec 3, 2015 04:42 PM
Thermo
Nov 5, 2015 11:05 PM
KP1723
Oct 12, 2015 07:47 PM
