Missing relay?
Old Feb 25, 2020 | 07:51 PM
Jaesteban's Avatar
Default Missing relay?
Good day everyone! I was cleaning and lubricating all connections I could find and I ran into this on the RH in front of the windshield wiper fluid. Am I missing something important?
Thank you!!
Old Feb 25, 2020 | 09:05 PM
Doug's Avatar
Thank you!!
Probably not. To simplify production Jaguar often installed wiring and sockets for a variety of equipment levels even if the car in question wasn't intended to be equipped with xxx-item. Often this is market-related with (for example) German market cars having some gadgets and gizmos not used on USA cars or UK or whatever
Old Feb 25, 2020 | 09:15 PM
Jaesteban's Avatar
Thank you!!!
Old Feb 26, 2020 | 05:36 AM
roman_mg's Avatar
My XJS (USA, MY 1988, V12) have two relays here. From scheme, one is air conditioning compressor relay, second stop lamp relay.
Old Feb 26, 2020 | 08:29 AM
Jaesteban's Avatar
Mine is a 1985 USA. Would the relay be exactly like the one beside it? Doesn’t hurt to try since my a/c is dead! Haha!
Old Feb 26, 2020 | 11:55 AM
JayJagJay's Avatar
Mine is a 1990 Convertible,,, and there I find an AC relay,,, and another (I forget what the "other" is). If you can switch on your AC with a multi meter hooked into 85 or 86 ports (I think this would be the "switch" lead) and see if you get juice... Electrics isn't my strong suit (by any stretch) but power here would switch on the higher amp power to the AC electro magnet to engage the AC clutch...
Old Feb 28, 2020 | 10:08 AM
Jaesteban's Avatar
Thank you roma_mg! How should I look for the one that is missing? What specs? Or would it be the same as the one that is there?
Thanks again!
Old Feb 28, 2020 | 02:23 PM
anyoldiron's Avatar
Banned
Thanks again!
Original item Bosch. 0332014113
Replacement https://www.ebay.com/itm/Relais-0320...53.m1438.l2649
Cheers AOI
Old Feb 28, 2020 | 03:48 PM
Jaesteban's Avatar
Thank you Sir! I got the 0332019151 which I understand is the new part number. Does that sound right?
gdiilk
Oct 2, 2019 08:53 AM
jal1234
Mar 14, 2016 09:39 AM
marvin.d.miller
Jan 24, 2015 01:49 PM
sws805
Dec 16, 2012 03:33 PM
StayFrosty
Oct 6, 2009 06:24 PM
