Trip computer light bulbs facelift
Old 04-22-2018, 07:56 PM
Time-Pilot's Avatar
Default Trip computer light bulbs facelift
I've been over every post I could find, which is how I was able to extract the bulbs from the trip computer. But now I'm stumped. I removed this "fixture" that the bulb appears to be soldered into.
When I found the part number for the bulb I found "LHD5180AA" which goes to a bulb that looks nothing like what I have removed.
https://www.terrysjag.com/SEARCH.html?Search=LHD5180AA
And before anyone asks, no LED's please I despise them. I just want to replace the original bulbs.
Old 04-23-2018, 01:17 AM
Jagboi64's Avatar
Received 3,056 Likes on 2,031 Posts
The bulbs are integral with the base. It's called a neo wedge bulb and come in different sizes that start with T, such as T3, T4 etc.
I'm sure an internet search will turn up a chart of sizes and you can compare to your existing bulb. They are fairly common in the auto industry for switch and dash lighting.
Old 04-23-2018, 07:14 AM
Vee's Avatar
Vee
Vee is offline
Received 1,510 Likes on 1,176 Posts
Neo Wedge T5
I have a post about installing LEDs and then inserting a “Saffron” light gel (from a theatrical lighting store) to return the color to its stock Aqua color.
I hated the way the incandescents bake the trip computer. When driving at night, hold your finger on the screen for 10 seconds, I doubt you’ll be able to do it. It gets hot!
The shift selector light also runs hot enough to melt plastic. (Open that assembly up and you’ll see some melted plastic). I changed that out to LED and added the same gel filter to correct the color.
Old 04-23-2018, 12:44 PM
Time-Pilot's Avatar
Got a pack of these for the clock:
https://www.ebay.com/itm/6Pcs-T5-T4-...eaed%7Ciid%3A1
They are listed as 12mm which is exactly what mine measured.
Old 04-23-2018, 10:20 PM
RonaldP's Avatar
The LEDs cut down on the heat in the display. https://www.superbrightleds.com/more.../Photos&Videos
Old 04-24-2018, 06:00 AM
Vee's Avatar
Vee
Vee is offline
Originally Posted by RonaldP
The LEDs eliminate the heat in the display. https://www.superbrightleds.com/more.../Photos&Videos
Fixed. Eliminating the heat will undoubtedly prolong the life of these ancient computers.
Old 05-08-2018, 06:52 PM
paulZ's Avatar
I found an X-300 in a Upull it yard. I now have a dozen or so of these things.
Old 05-09-2018, 06:16 AM
Vee's Avatar
Vee
Vee is offline
Don’t tell me you came across several trip computers...
Old 05-10-2018, 01:13 PM
paulZ's Avatar
X-300 Trip computer?
I am ignorant of your Jag model. This is the chip from an X-300
Old 05-20-2018, 10:12 PM
Time-Pilot's Avatar
All done.
paulZ (05-21-2018)
Vee
12-07-2013 02:56 PM
Vee
07-20-2013 03:12 PM
priest2705
03-04-2011 09:47 AM
frombenz2jag
01-01-2008 03:09 PM
Quick Reply: Trip computer light bulbs facelift
