V12 timing chain tensioner hole plug
Old Nov 28, 2018 | 02:46 AM
Greg in France's Avatar
Default V12 timing chain tensioner hole plug
The OEM rubber plug that seals the access hole to release the timing chain tensioner always leaks and fails quickly. A guy called Ron Kelnhofer in the USA used to make a top notch aluminium replacement, but no longer does.
I have just seen an advert for one on a well known auction site, and post it in case anyone is interested. I also attach a pic of the one from Ron that I fitted, and a "before" pic showing the OEM. This is a really worthwhile upgrade IMO.
https://www.ebay.co.uk/itm/Jaguar-V1...~kTg:rk:2:pf:0
Old Nov 28, 2018 | 04:16 AM
warrjon's Avatar
I was thinking about this the other day. As I have everything off the front of my engine I was about to make one from aluminium that tightens an O ring.......
Old Nov 28, 2018 | 06:38 AM
Steve M's Avatar
And at a pretty price too!
Old Nov 28, 2018 | 08:13 AM
Think of the oil top-ups it will save, Steve!
Old Nov 28, 2018 | 09:51 AM
Steve M's Avatar
Absolutely nothing wrong with continually running fresh oil through the engine.
Old Nov 29, 2018 | 06:24 PM
ronbros's Avatar
STEVE , NO problem, my fix and it works , $3. dollars at plumbing store, been there for 5yrs now.
Old Nov 30, 2018 | 07:09 PM
Dukejag's Avatar
Greg,
Guess what I made yesterday....
I Just need to get the viton oring.
Drilled right through M6 - will use hydraulic loctite to seal the screw in place.
And some gasket cement - non hardening stuff.
First i will need to clean the hole.
The hardest part was removing the old bung, drilled a small hole and used a o-ring hook to try and pull it out.
Only way to remove was in bits.. lots of bits.
Old Nov 30, 2018 | 07:12 PM
Dukejag's Avatar
better picture
Old Nov 13, 2021 | 08:00 AM
Rescue119's Avatar
What plumbing part did you use if you remember?
Gladiator
Jul 16, 2016 07:02 PM
swayne
Apr 24, 2015 12:03 AM
slanham
General Tech Help
Feb 1, 2014 06:34 PM
