what causes stomp and bog when engine is cold? 93XJS4L
Old Dec 12, 2011 | 06:16 PM
deadboy1977's Avatar
Default what causes stomp and bog when engine is cold? 93XJS4L
Only happens when cold, none of my other cars do this. No FF codes.
Stomp on gas and bog/sputter when engine is cold, any ideas appreciated.
When warm this does not happen~
Old Dec 12, 2011 | 07:07 PM
M90power's Avatar
AFR gauge FTW!
Old Dec 13, 2011 | 01:34 PM
OK if the air to fuel ratio is off (what is it supposed to be anyways??), what does one do to fix it?
Old Dec 13, 2011 | 06:09 PM
M90power's Avatar
well, if its off, youd have to fix whateveres wrong with your jag and throwing it off. Vacuum gauge is another wonderful tool.
Old Dec 13, 2011 | 08:43 PM
M90power's Avatar
also fuel pressure gauge.
Old Dec 14, 2011 | 07:25 AM
Fuel P is steady at 38 psig, book states 35-45 psig as a range
Old Dec 14, 2011 | 11:46 AM
Fraser Mitchell's Avatar
When cold the engine needs to draw more fuel, so if fuel pressure is OK as it seems to be, the injector pulse is too short, indicating perhaps your engine temperature transmitter is not right.
The two biggest influences on fuel supply are (1) engine (coolant) temp and (2) mass air flow. As you don't get the problem when engine is hot indicates to me it is not a mass air flow measurement problem
Old Dec 14, 2011 | 06:10 PM
M90power's Avatar
the intake air temperature is also a major factor in AFR. although im not sure if it applies to the 5.3
SD96XJ6L
Jan 12, 2022 04:30 AM
cissdm
May 3, 2016 06:02 AM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
tberg
Sep 7, 2015 07:32 AM
Corycarlo
Sep 5, 2015 11:41 AM
