Wheel lug nut washer
Old Sep 18, 2020 | 06:57 AM
scottpeterd's Avatar
Default Wheel lug nut washer
One of mine has gone missing.
Anyone know a source?
Old Sep 18, 2020 | 07:15 AM
I cannot find the washer as supplied on its own.
They are encapsulated with the nut, well all mine were, as are the newer members of the fleet.
Depends on the wheels fitted.
Starfish wheels = CAC4549, I am finding NLA
All others seem to go to CCC7028.At $68 Each, and I am assuming US$??
Old Sep 18, 2020 | 07:43 AM
Doug's Avatar
Some washers intended for aftermarket wheels/nuts might be close enough to work? Lots of choices out there; here's one random sample
https://www.summitracing.com/parts/mcg-78711
You'll have to measure shank diameter, etc
Old Sep 18, 2020 | 07:49 AM
Doug's Avatar
If you ever shopped for used Jag wheels you've noticed that nobody ever includes the lugnuts. This is why. They're like gold
Foggy memory disclosure but I'm 95% sure I've used both types interchangeably. For the 7028s there are some less expensive replacements....although still not cheap if you happen to ever need all 20!
https://www.autohausaz.com/pn/CCC007028?utm_source=google&utm_medium=cpc&utm_cam paign=frooglePN&utm_term=CCC7028
Old Sep 18, 2020 | 10:28 AM
Greg in France's Avatar
Loads for sale on UK ebay. Search for "wheel nuts"
Old Sep 18, 2020 | 07:31 PM
Ok. Spent the day examining the original lattice wheel, and the Alessio’sthat I have. I am currently using the original lug nuts after fitting the Alessio’s. I shattered two of my original lattice rims in my accident
Frankly, not sure why the lattice rim does not use shank style lug nuts,
i have ordered what I think are the appropriate shank style lug nuts to go with the new rims, I should have known this, as I had to do it with my 928 when I changed rims from the 16” phonedials, and with my TVR when I went with Nissan rims from a 280z
Old Sep 18, 2020 | 08:08 PM
Doug's Avatar
Your lattice lugnuts should look like this
Is that what you mean by "shank" type?
Old Sep 18, 2020 | 08:28 PM
Mine do not look like that. Except for the champher, that is a shank style
Old Sep 18, 2020 | 08:59 PM
Xjeffs's Avatar
Default Lug nut washing machine
I'll be honest, I am reading this thread because I had no idea why there was a discussion on techniques and equipment to wash lug nuts.
Old Sep 18, 2020 | 09:03 PM
Doug's Avatar
I was um.....mis-remembering anyway. Old age. Long day. Sore back. And the sun was in my eyes
The pic I posted above is a lugnut for a Starfish wheel, not Lattice.
Old Sep 18, 2020 | 09:17 PM
Doug,
That makes sense, as the Starfish have different p/n from the lattice
BTW, cant wait to get the beast out to the Pacific Northwest next week
Old Sep 18, 2020 | 09:59 PM
Wait for the thread about washing your exhaust system
Old Sep 19, 2020 | 12:19 AM
The only difference between the starfish and the lattice wheelnuts is the length of them, the starfish being longer as a result of their deeper hole. The captive washer is the same on both.
I have some lattice nuts for you Scott if all else fails. Free to a good deserving home, but you pay the postage.
Old Sep 22, 2020 | 06:17 PM
equiprx's Avatar
Send me a pic of one to my phone 650-455-1110.
Once the washer separates from the nut it's dead.
I'll send you as many lug nuts as you want for the cost of postage.
Steve
Old Sep 22, 2020 | 08:38 PM
Steve,
Thanks so much for the offer. 3 of mine have lost their washers.
why do you say they are dead?
I spent the afternoon grinding several washers to fit in the recess of the lug nut cap.
Old Sep 23, 2020 | 05:54 PM
Rescue119's Avatar
Mag style lug nuts are the style with the washers. I got a set from a company in the US. I posted pics in my build thread.
Old Sep 24, 2020 | 05:44 AM
equiprx's Avatar
I thought I sent a reply to your last question but I can't find it.
I'm certainly not an expert but I suspect that once a washer separates from a lug nut, one of the two are somewhat deformed.
My thinking is that such a deformity will have an effect the torque applied on the studs.
One other thing I mentioned is that I use a dab of anti seize on the threads every time I remove lug nuts.
srpope80
Oct 23, 2019 09:50 PM
kstevusa
Mar 4, 2018 09:46 AM
flyrr100
Nov 17, 2012 04:35 PM
kiloslanga
Dec 31, 2008 11:49 AM
