Winter Project Cam Covers Oil Leaks
Old May 3, 2022 | 01:51 AM
Dukejag's Avatar
Default Winter Project Cam Covers Oil Leaks
Winter Project Cam Covers Oil Leaks.... I am thinking this will be an excellent winter project.
I am a little worried about getting it running again after this.
From a tuning point of view is there anything I should be scared about?
I would like to build a list of part to order before I start...I know this has been done many times so I do very much appreciate your input.
So here is my list so far...what else?
2 x Cam cover gaskets - Gortex gaskets Part Numbers EBC 9627 & EBC 9628.
Radiator hoses
Spark plugs... they are not that old.
Clean injectors
Injector hoses.. mine look new but have hose clamps on them... I would like to remove these but they might have to be used.
Oil temp sender
Oil Pressure sensor
Old May 3, 2022 | 02:05 AM
Greg in France's Avatar
Aluminium half moon blanks?
https://www.ebay.co.uk/itm/324493972...EAAOSwjqNgMnCn
Old May 3, 2022 | 04:03 AM
Inlet manifold gaskets.
Hi-Temp RTV, Grey of course.
The 90deg elbow on top of the AAV.
Oil fill cap O/ring seal.
BEER, lots of it.
Old May 3, 2022 | 05:32 AM
JayJagJay's Avatar
All everyone else has mentioned,,,
And be careful about dropping stuff into the top of the engine once the intake is off. Especially if you plan on having the intakes off for an extended period of time. Lots of little bits and bobs floating around.
All the oil sender stuff is easy-er to get to.
One cool thing, once everything is off,,, the covers for the manifolds are right there, two bolts each side, and them ol things can be cleaned up and resprayed any color ya like - as long as it's high temp engine paint.
The intake, fuel rail, the skinny Y-ish vac pipe, cross/balance pipe can be removed in one large chunk, brought to a good place for working, disassembled and worked on on the side as well.
The engine bay is a LOT different and accessable without the intake and all that is attached to and surrounding it.
Old May 3, 2022 | 05:45 AM
ptjs1's Avatar
Duke,
I'm in the same position as you, and I have a new injection harness as a priority item on my list of parts to buy.
Also trying to work out which items need to be blasted, plated, painted etc
Paul
Old May 3, 2022 | 10:35 AM
Dukejag's Avatar
Thanks Guys... yes it is a great opportunity to look at all those small things.
Paul - yes I enjoy doing all the cleaning up...
new injection harness - make or buy? Paul what are you doing here?
2 x Cam cover gaskets -Gortex gaskets Part Numbers EBC 9627 & EBC 9628.
Radiator hoses
Clean injectors
Oil temp sender
Oil Pressure sensor
Aluminum Halfmoon Bay Blanks
Inlet manifold Gaskets.
new injection harness - where do I get one of these?
Old May 3, 2022 | 11:44 AM
Thorsen's Avatar
I recommend ordering the aluminum half-moon seals sooner rather than later. When I ordered a set last year it took a few months to make it through customs.
Old May 6, 2022 | 10:35 AM
Dukejag's Avatar
Thanks for the imput... so far...
Radiator hoses 29-8604 XJS V-12 VIN 185820 to 190527 - Moss - $114
Clean injectors
Injector hoses.. .
Oil temp sender - Have
Oil Pressure sensor - Have
Aluminum Halfmoon Bay Blanks - Have
Inlet manifold Gaskets - Gasket to cylinder Head - NNA3020BA - x 2 $20.99 (3)
Rear Gasket EAC 9819 x 2 - $1.19 (5)
Gasket manifold to throttle housing EBC9635 - $3.89 x 2 (6)
Gasket Front EAC97661JAG XJS - through to 1991 - $2.09 x 2 (8)
Ignition Leads -
Have
Jaguar V12 Badge - EBC2843JAG x 2 - $94.89 (1)
Thermostat Gasket RH - EBC8330 x 1 - $1.99
Thermosta Gasket LH - EBC8331 x 1 - $1.69
Mount Grommet C37990 x 4 - $6.99 (46)
Gasket pump to Casting EBC9636 x 1 - $1.29 (13)
Heater Valve C41051 $47.99 x 1 - (30)
VivaJag
Oct 7, 2019 09:46 AM
jordanmc
Sep 23, 2017 03:24 PM
jaguarguy13
XJ40 ( XJ81 )
Dec 30, 2014 11:32 PM
Dan R
Aug 13, 2014 03:57 PM
BigWill
Jan 2, 2008 05:48 AM
