2007 Jag XK Glove Box Lock Assembly
Old Apr 30, 2011 | 11:31 AM
austinmartus's Avatar
you are probably stuck with the dealer or a junk yard.
Old May 8, 2011 | 01:09 PM
Teck4Jag's Avatar
whats your trim code,ill get you the number pm me
Old Feb 16, 2017 | 02:44 PM
tnt10's Avatar
Didn't want to have to start a new thread on this, so I'm reviving this older one.
The sleeve on my glove box lock just broke and popped out. Indie is ordering a new one.
Any idea of cost on this part??
Thanks,
tnt10
Old Feb 18, 2017 | 08:09 PM
tnt10's Avatar
Thanks,
tnt10
Anyone??
thanks
tnt10
Old Feb 18, 2017 | 10:30 PM
Cee Jay's Avatar
You seem lonely..... I'm no help.
Old Feb 24, 2017 | 11:19 PM
tnt10's Avatar
Well, just had the plastic part around the glove box lock replaced by my indie mechanic.
The part was $125.00. Labor for 3/4 hour work was $97.50.
The entire glove box had to be removed to replace all parts.
Good news, such as it is, I had the mechanic fix the dropping glove box door while he had the glove box out, which he did following the info I had gleamed on this site about how to do it.
So for $222.50 , not only was the glove box lock plastic surround replaced, but the broken glove box door damper was repaired!
Actually worked out pretty well.
tnt10
Old Feb 24, 2017 | 11:45 PM
Cee Jay's Avatar
tnt10
That actually sounds like quite a bit more than it should. The glove box removal is a whopping four screws. The fix to the flop is to put one small screw where the post broke off. I guess maybe the replacement of the lock sleeve was the biggest charge? I've not looked at that.
Old Feb 25, 2017 | 01:25 AM
u102768's Avatar
5 screws actually so you would have to add another 5 seconds or so.
I fixed mine a few weeks ago and went with the tie wrap around the arm method mentioned on another thread as it is less invasive.
Old Feb 25, 2017 | 06:35 AM
kj07xk's Avatar
It always takes me a lot more time getting that thing back in, than taking it out. I've done it 3 times now, so you'd think it would be easier, but no, its always a pain to get back in.
Old Feb 25, 2017 | 08:00 PM
tnt10's Avatar
Considering the plastic lock surround was going to be about the same amount to fix, the addition of the damper repair was probably 5-10 min more in labor.
Still worth it to me, as I'm not handy and would never have fixed the damper issue myself.
tnt10
Old Aug 31, 2018 | 10:14 PM
Indigo's Avatar
Hi
Was it the black collar that has the eyelet for the glove box latch ? If so what wa the part number ?
My eyelet broke on mine
Old Sep 1, 2018 | 05:08 PM
winstonsalemncxk's Avatar
My XK either doesn't have a glove box damper or the damper is broken. Can you chime in on this? Do you have a damper on your glove box? Mine's an '07 (US model year).
Old Sep 1, 2018 | 05:42 PM
Cambo's Avatar
This is a RHD glovebox, removed from the car, LHD will be a mirror image.
The damper is the white tube on the back, there's a string which goes around and attaches to a clip, which always breaks. On this car I just hooked the string onto another spot, it's a bit too strong but works ok.
Both the upper mounting screw locations on this one were broken by someone previously.
There are five T30 torx screws holding the glovebox in, two at the bottom, two at the top (access from inside the glovebox) and one on the side, behind the plastic end cap of the dashboard which nests into the cutout of the door card.
Old Sep 1, 2018 | 06:01 PM
kj07xk's Avatar
Your damper is broken, or as Cambo says, the string coming out of the damper is no longer connected to anything.
Had the same problem on mine when I bought it. The wife said 'how come the door just drops down?'. Did research on this forum and found workable solutions.
Took out the box and repaired it (hardest part, for me, was getting the box reinstalled). Works great now.
Old Sep 2, 2018 | 12:40 AM
Indigo's Avatar
Yea , the white tube on the back is the damper and if the hoop is good just drill 2mm hole and use a cotter pin .jaguar has a service bullitin on this .
D.K
Dec 10, 2023 02:05 AM
allenman85
May 10, 2021 03:11 PM
tberg
Sep 7, 2015 07:32 AM
TC Johnson
Sep 2, 2015 09:30 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
