can't get gas into tank 2007 XK
Old Jul 2, 2013 | 06:15 PM
britannia's Avatar
Angry can't get gas into tank 2007 XK
Went to fill today and it won't take gas; tried different pump, no go. Tried another station ; no go...........
Any ideas please?
thinking to check the CCV (canister close valve)! Is there one?
Did a search nothing for XK's
Never tried to refill with such an empty tank; but don't see any relevance.
Cheers, Adrian
Old Jul 2, 2013 | 08:05 PM
Sandtrap's Avatar
I had the exact same thing happen a few months ago, it took about 10 minutes to put in a couple of gallons. I have since filled up about ten times with no problems. No idea how it fixed itself..
Old Jul 2, 2013 | 09:28 PM
Stuart S's Avatar
Adrian,
The gasoline nozzle is shutting off prematurely because of back pressure from your tank; it's as if your tank was full (but it's obviously not). When gasoline goes into the tank it displaces an equal volume of air/gasoline vapor. But if the vent line from the tank to the charcoal canister is clogged up, that air/vapor can't get out of the tank. So when you try to fill up, back pressure causes the nozzle to shut off. Before spending big bucks to have your clogged vent line replaced, try to clear it out by giving it a few short blasts of low-pressure compressed air.
One common cause of a clogged vent line it overfilling the tank, which can cause fuel to get into the vent line and clog it up. Think of that vent line like the trap under a sink - if that vent line has a dip in it and gasoline gets into that dip, it can prevent air/vapor from getting past. That's one reason why gas stations have signs that tell you to not top off your tank, in addition to preventing spills.
Also, some gas station nozzles are more sensitive than others and can't dispense fuel at a fast rate. Try pumping slower, by setting the fill trigger lever on the pump handle on the bottom notch.
Let us know if this helps.
Stuart
Old Jul 3, 2013 | 03:21 PM
britannia's Avatar
Stuart,
Tried using a gas can; after a minimal amount (ozs) gas stayed in filler neck.
Still looking for vent pipe & cannister ! I was able to blow vacuum cleaner air into filler; didn't help.
Will remove right rear fender liner next and take a look..............
My JTIS XK Disc no help.............
So...........
Thanks , Adrian
Old Jul 3, 2013 | 04:31 PM
Hailers's Avatar
These jpgs attached might help.
Looks like that puppy is located on the top of the tank. Not a real fix, but...........if you can get a couple of gallons in the tank (real slow to happen in your case), I'd drive that car in a wild and crazy manner for a few miles hoping something good happens. As in shaking 'something' loose to fix the problem.
Your problem scares me. I'd hate to be 1000 miles away from the house with this problem.
Attached Thumbnails can't get gas into tank 2007 XK-flvvone.jpg   can't get gas into tank 2007 XK-flvvtwo.jpg   can't get gas into tank 2007 XK-flvvthree.jpg
Old Jul 3, 2013 | 11:29 PM
tnt10's Avatar
I had the same problem with my 2007 XKR. Went to another gas station, and no problem filling the tank. Assumed it was not my car but rather the stations nozzle....
tnt
Old Jul 9, 2013 | 09:55 AM
britannia's Avatar
Problem fixed; misread fuel gauge! tank was full............and dealer cleaned vent pipe
only $120 and a smile!................ it appears old age (me!) was basic cause.
Very Happy now!
Thanks for inputs chaps, Adrian
Old Jul 9, 2013 | 10:21 AM
amcdonal86's Avatar
Hahahahhaah! That is hilarious.
Hopefully you didn't overfill the tank and flood the breather line, because then you really might have a problem filling the tank later!
Old Jul 9, 2013 | 03:05 PM
Muddydog's Avatar
And the award goes to...
Old Jul 9, 2013 | 03:15 PM
jimbov8's Avatar
It could happen to anybody.
Old Mar 8, 2017 | 01:49 PM
AltoPaul's Avatar
Default 02 XK8 ran out of gas because thought gauge not working
Had never heard of the vent issue on filling tank. Like many above, I tried 2x to fill my tank only to get air/gas blast back first time and only 1 gal 2nd time. Figured I was full and gauge not working. But I finally came to a stop and had to be towed to my mechanic who blew out charcoal bilts in the vent line. Weird.
the note tonot overfill sounds like a good idea! Thanks for all the info in these posts. AltoPaul
Old Mar 8, 2017 | 03:26 PM
Big Otter's Avatar
Very Happy now!
Coincidentally, marijuana is legal in Washington State (personal consumption <1oz).
Just putting that out there...
Old Mar 8, 2017 | 04:55 PM
kj07xk's Avatar
Started reading this thread thinking I was going to find out why filling the tank on this car is so slow compared to any other car I've owned.
Ended up with a few ideas and a great laugh (unfortunately at your expense Adrian!).
Old Mar 8, 2017 | 05:43 PM
Cee Jay's Avatar
This happened to my F250 pickup. I swapped out the Evap canister and all is well.
njburlington
Sep 22, 2020 07:03 AM
Ragn0r
Sep 19, 2015 08:39 AM
pab
Sep 16, 2015 10:34 AM
tsimms7
Sep 15, 2015 12:43 PM
alpecsa
Sep 7, 2015 11:55 AM
