Changing Pads and Rotors
Old Jul 10, 2015 | 08:21 AM
jnporcello's Avatar
Default Changing Pads and Rotors
My brother is coming into town this weekend and wants me to help him change his Pads and Rotors on 2007 XK. I am a novice/beginner at mechanical work - I've probably changed 10 different vehicles brakes and rotors. Usually goes OK, sometimes hard to get the caliper bracket off or getting the rotors themselves off. But I live in NE with lots of road salt and corrosion, where he is coming in from Charlotte, NC which should negate that frustration. Is there anything special I should know about this particular brake job before beginning?
Since he's coming in from out of town, I don't want to have a problem in the middle which would prevent him from heading back after the weekend.
Old Jul 10, 2015 | 12:25 PM
CleverName's Avatar
I did have to go buy a special size for the job, but I encountered no real issues. Other have said they had problems with the e-brake afterwards requiring the shop to reset, but I did not experience this...
Old Jul 10, 2015 | 01:01 PM
NBCat's Avatar
Be sure you have the necessary tools to reset the pistons for the rear brakes, if those are also to be replaced.
It is also a good idea to change the brake fluid if that has not been done within the past two years. Be certain to use the correct specification brake fluid.
Old Jul 11, 2015 | 01:43 AM
CleverName's Avatar
opps... fergot about dat tool... needed it too.... (Free rental from AutoZone)
Thanks for the catch...
V
Old Jul 13, 2015 | 06:46 AM
jnporcello's Avatar
Thanks for the info. Knowing it was going to be pretty straight forward going into it helped. Whole job was done - all 4 with pads and rotors in a little over 3 hours. Lost about an hour b/c somebody already rented the tools for the rear. I was able to do it with a little square tool they sell, but not without a lot of wasted time. You have to really push in (a lot) while turning the piston. After I figured out to push harder, we got it done.
Old Jul 14, 2015 | 02:01 PM
RedRider48's Avatar
OK, so the trick to resetting the caliper piston, is to insert a tool with a "square" that allows one to "turn" CW while pushing to recess the piston?
This sounds like the old FORD process from years ago.
Thanks for sharing your experience.
Old Jul 15, 2015 | 06:12 AM
jnporcello's Avatar
Exactly, and push in hard. I was turning while pushing and nothing was happening. You have to really push down hard while turning.
Old Jul 15, 2015 | 06:33 AM
jagtoes's Avatar
The cube "square" one is a pain to use so if you can borrow or buy one of the better tools do that.
https://www.google.com/webhp?sourcei...+tool&tbm=shop
Old Jul 15, 2015 | 07:40 AM
RedRider48's Avatar
Thanks , I have one like this cube. But the other style shown would be much easier. Anyone know the measurement between the pins?
Attached Thumbnails Changing Pads and Rotors-my-pad-retraction-tool.jpg   Changing Pads and Rotors-rear-pad-retraction-tool.jpg
Old Jul 15, 2015 | 12:39 PM
britannia's Avatar
Get a universal brake caliper tool kit from Harbor Freight ................it will push and rotate rear caliper................
Cheers, Adrian
Old Jul 15, 2015 | 12:49 PM
britannia's Avatar
PS............
Always bleed off old fluid from caliper into a container; you don't that stuff pushed back into the system.................
Adrian
Old Jul 15, 2015 | 02:09 PM
RedRider48's Avatar
Cheers, Adrian
Should you not, determine if the HF tool's pin distance is correct for our Jag caliper pistons? I'm just trying save someone the aggravation of buying a tool getting home and finding it not be correct.
Old Jul 15, 2015 | 03:21 PM
jagtoes's Avatar
A friend of mine has a kit from Snap on which has an assortment of ends that fit most cars. There was one that work in my 77 Ferrari so there were others that would fit Jags. I know there are other cheaper kits but you would need to look for them.
Old Jul 19, 2015 | 02:45 PM
luv2fly's Avatar
I bought the Harbor Freight tool some years back and it works fine, multiple adapters. 04 XJR and 07 XKR.
Old Jul 21, 2015 | 11:36 PM
CleverName's Avatar
Again, Autozone loans tools for free (deposit required).... Great for those one time (or once every few years) jobs...
H20boy
Dec 24, 2024 03:23 PM
ym37tech
Feb 8, 2016 01:04 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
handcuffsready
Sep 7, 2015 01:02 PM
JagLove86
Sep 6, 2015 10:36 PM
