How do you wire up a reversing camera?
Old Dec 5, 2017 | 11:56 AM
Python's Avatar
Default How do you wire up a reversing camera?
I want to fit one to my 2011 XK Portfolio no other model please.
Where precisely do I tap into the rear backup lights and as some have said
are these LED lights pulse driven or not on my particular model?
If these lights do indeed cause the camera to flicker can this be resolved and how?
The system I hope to fit will be WI-FI wireless to a cell phone.
Hoping you can help.
Old Dec 5, 2017 | 12:32 PM
Cee Jay's Avatar
The best, easiest and cheapest way to add a Backup Camera????
Sell your 2011 and buy a 2012+.
Seriously.
Old Dec 5, 2017 | 12:39 PM
RedRider48's Avatar
Perhaps, this is an alternative....
Amazon Amazon
Old Dec 5, 2017 | 01:43 PM
Sean W's Avatar
Reach out via PM to KJ07XK. He has an 2007 but he installed LED rear lights. So essentially he had to overcome the same problem. I believe a relay solves the problem but he can let you know the specifics.
Old Dec 5, 2017 | 04:39 PM
pwpacp's Avatar
Just no easy way to add back up cam to the pre 12 xk. I opted to go with a Garmin unit that had wireless back up cam capablitiy on my 07 xk. It worked well but did mean that another device was sitting in the cabin's console area. The good news though was that it did not require intervention to make it work, just start up and go, unlike some options that integrate to the nav screen. You can read volumes on the subject in other threads....as I did before opting for the Garmin on the 07.
Ultimately I moved on to a 12 vert so the Garmin found it's way to my pickup truck.
Old Dec 5, 2017 | 05:54 PM
kj07xk's Avatar
As 'Sean W' said, I do have the LED taillights on a 2007. I followed the instructions posted by George Kale (in a nice PDF) on how to do it. I then added a HKS Camp-2 via a GVIF interface (to get gauges on my infotainment screen), following instructions posted by owner 'flyc2c'. Once I had the GVIF interface, it was 'easy' to add a backup camera, and tap into the brake light wiring for the LED taillights.
I don't think you'll have a pulsing problem on the 2011, I suspect it is a steady voltage.
The pre-LED cars are pulsing the brake lights, but you don't see it because the incandescent lamps absorb it. A relay is used when putting the LED lamps on a pre-LED car, to give the LEDs a steady voltage so they don't flicker.
Pin #2 on both the left and right tail lamp units is the brake light.
(See post #99 in this thread: https://www.jaguarforums.com/forum/x...s-36907/page5/)
Here's a link to George's excellent instructions for the tail lamp conversion (although his mapping of the old to new wiring is a bit confusing, and I clarified it in the post referenced above):
https://www.jaguarforums.com/forum/a...ps-upgrade.pdf
The PDF was originally posted by George in post #66 in this thread:
https://www.jaguarforums.com/forum/x...d-55139/page4/
Old Dec 6, 2017 | 09:20 AM
Python's Avatar
Thanks for replies so far especially kj07xk.
I think you miss understood my question.... sorry.
My2011 is standard equipped with LED rear lights.
A I-phone 4/5/6 etc or a Samsung galaxy 2/4/5/6 will fit flat in ash tray unit once removed.
Then a specific app. can be installed to link to the camera Wi-Fi thus using a used cell phone only as a screen (the app shows green/yellow/red grid lines also)
All I need to do is connect to the power line to a reversing light so the camera is only on when reversing and the feed to the lights is not pulsed.
Hope this clarifies my questions thanks people.
Old Dec 6, 2017 | 12:53 PM
chazaroo's Avatar
https://www.amazon.com/gp/offer-list...condition=used
That company went out of business in June and there is no tech support.
Old Dec 6, 2017 | 02:25 PM
kj07xk's Avatar
My bad sorry, you want the reverse lamp circuit, not the brake lamps.
See the above referenced PDF, page 9 and 19. Connector BL001, pin 3 (orange/green wire) should be the reverse lamp circuit (test it before using it, otherwise it might be pin 2, the orange/yellow wire).
The connector (dark grey) is behind the trunk liner on the left side of the trunk (boot).
Again, I don't think you'll have pulsing on your car, otherwise the LEDs would flicker.
Old Dec 6, 2017 | 03:19 PM
Sean W's Avatar
or right here in the aux junction box behind the back seat center rest
Same wire as KJ/ George reference, just at the junction box upper left side.
