Long Term Trim -20 both banks
Old Jun 14, 2019 | 06:50 PM
Ronald MacGarvey's Avatar
Default Long Term Trim -20 both banks
2008 XKR running rich with long term trim averaging -20 causing P072 and P075 setting off check engine light. Replaced upstream O2 sensors, maf sensors, plugs, cleaned airfilters and changed nothing. I have aftermarket airfilters which shortens the tube to the filter to about 18 inches and was told by one mechanic that I needed the stock system. Anyone seen this before and have any ideas? Thx, Ron
Old Jun 15, 2019 | 03:14 AM
Welcome to the forums Ron,
I've moved your question from General Tech Help to X150 forum. This is the place to post technical questions about your model.
Old Jun 15, 2019 | 06:47 AM
Stuart S's Avatar
Good advice from that mechanic. The OEM Genuine Jaguar engine air filters are sold in a matched set of 2. Using aftermarket filters is a crapshoot.
Read Brutal's Post #8, here: https://www.jaguarforums.com/forum/x...esolved-92749/
Old Jun 15, 2019 | 09:33 AM
Thank you so much Stuart, I will follow your advise. Best regards, Ron
Old Jun 15, 2019 | 10:38 AM
Stuart S's Avatar
Welcome to the Forum, Ron. There are many helpful and knowledgeable members here and a great Advanced Search function to help you find the answers to most of your questions. For example, it took me less than a minute to find Brutal's post. Be sure to browse through the "Stickies" at the top of this Forum's Home Page and create a signature that includes your model year and any other information that you want to share. Post some pics! I hope you enjoy your XKR as much as I enjoy mine!
Stuart
Old Jun 18, 2019 | 12:05 AM
AlexJag's Avatar
Sponsor
Can you post some photos please of what after market intake setup that you have here? Also did you replace maf with
DENSO brand or something else?
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old Jun 18, 2019 | 09:10 AM
Default After market Filter
The filter system is from Mina Galleries and this picture represents what it looks like with one feeding the left and the other feeding the right. The MAF sensors that I installed were Jaguar OEM. Thanks for your interest. Ron
Old Jun 18, 2019 | 11:06 AM
Cee Jay's Avatar
Did you ever do a Hard Reset after your mods? If you haven't, the car still wants to drive on it's initial 'learn' and is trying to make that work right.
Old Jun 18, 2019 | 04:47 PM
I will try that ...thank you for the input. Ron
Old Jun 18, 2019 | 07:10 PM
Thank you! Ron
Old Jun 18, 2019 | 11:29 PM
Cee Jay's Avatar
Thank you! Ron
Does that mean you have some positive results?
Old Jun 19, 2019 | 06:11 AM
Not yet but I will let you know when I have tried it. Ron
Old Jun 19, 2019 | 07:01 PM
Default Hard Reset
After hard reset the values settled back in to the -20 range left and right. I am going to go to the stock filter system as was recommended and see if that solves the issue.
Old Jun 23, 2019 | 01:25 AM
AlexJag's Avatar
Sponsor
In your mina intake setup were is maf positioned
? Is it in the same tube as oem or is
it now sitting in a wider tube? If its the later that will screw up the readings
Old Jun 23, 2019 | 09:17 AM
I think that is the situation which will hopefully be resolved by installing a stock system. Thanks, Ron
Old Jun 23, 2019 | 01:10 PM
AlexJag's Avatar
Sponsor
There is nothing wrong with aftermarket systems but when you mess with maf housing tubing diameter by enlarging it , that will cause ecu to read less air than is actually what maf is scaled for.
__________________
Old Aug 17, 2019 | 01:53 PM
Default Long Term Trim problem solved
Thank you for all the input as I worked through the trim issue. Ultimately I purchased and installed a stock filter system as recommended by Stuart S and the trim values have settled in at plus or minus a max of 2 both sides and the car runs great. The location of the maf sensors which differed from the after market system seems to be the source of the error. Problem solved!
Juan Torres
Nov 19, 2017 02:55 PM
Bob Jenkins
Jun 27, 2016 01:20 PM
alan24
Jul 1, 2015 02:27 PM
amarcd
Feb 8, 2015 10:20 AM
blue968
US Northeast
Mar 10, 2013 07:06 PM
