Oil usage
Old Oct 16, 2016 | 05:33 PM
jagtoes's Avatar
Default Oil usage
Being we talk about checking the E-Stick I was wondering if anyone has used oil and have seen the E-stick go down. I haven't in the 2 1/2 years and 2 oil changes so do these engines use any oil ???? Just wondering
Old Oct 16, 2016 | 06:22 PM
richzak's Avatar
I have a 2009 XKR and the oil stick level remains constant. I see no indication of my XKR burning any oil. The XKR has performed flawlessly in 3 1/2 years of ownership.
Old Oct 16, 2016 | 10:36 PM
Fstbmw1's Avatar
My 07 XK has never required the addition of any amount of oil in between changes. So far so good.
Old Oct 17, 2016 | 06:23 PM
ralphwg's Avatar
On my 3rd XK/XKR and have never added any oil to any of them in over 100K miles of usage.
Old Oct 23, 2016 | 02:15 AM
pk4144's Avatar
Damn. I lose about a pint every 3,000 miles. And no leaks so it's gotta be going out the tailpipe.
Old Oct 23, 2016 | 08:30 AM
tberg's Avatar
pk144,
I lose about the same on my 2010 XKR, so you're not the only one.
Old Oct 23, 2016 | 08:42 AM
jagtoes's Avatar
Originally Posted by tberg
pk144,
OK so we are all on the same page I guess part of the question is how many miles are you changing the oil at. For me when I say there is no change or loss of oil it is within 5,000 miles where I do an oil change and not the 10,000 range recommended by my dealer. Also depending on the amount of driving I do it is sometime less then 5,000 but I do change it once a year. So maybe I should have asked at what mileage are you seeing oil usage and how much.
Old Oct 23, 2016 | 03:21 PM
pk4144's Avatar
Had the car for a little over a year and have done two changes, and I'm putting a lot of miles on. So I guess my interval's 6 mos/7,000 miles.
Old Oct 23, 2016 | 04:24 PM
Fstbmw1's Avatar
Change the oil at 8500 to 9000 kms. No need to add any oil between changes.
Old Oct 26, 2016 | 04:56 PM
Polyesterpig's Avatar
If you are using oil, it might be a defective PCV valve. Especially a high mileage vehicle. Cheap inexpensive fix.
ecamiel
Sep 1, 2019 03:37 PM
dhvoorhees
May 14, 2018 07:22 PM
pac72
20
May 11, 2017 10:23 AM
rfarmery
Oct 12, 2016 10:33 AM
1964Daimler
Oct 4, 2016 10:02 AM
