Parking Brake Fault (yes, again)
Old Apr 29, 2021 | 06:26 PM
quantumspores's Avatar
Default Parking Brake Fault (yes, again)
Hi Folks - I'm looking for some advice on the dreaded "Parking Break Fault" error message (on my '08 XKR). I have read the other posts on this topic but haven't had any luck just yet. Here is what I've done or evaluated.
1. I've tried recalibrating the parking brake through both the method mentioned in the post below and by pulling the negative battery cable. Each time I've done this the problem returns after recalibrating. Link: http://www.jaguarforums.com/forum/xj...-fault-139538/
2. I've replaced the the rear brakes pads with new ones (the rotors are in excellent condition). Again, after re-calibrating the error returns.
3. There are no visible issues with the system and the parking brake is not hung up.
4. The battery is less than a year old (changed in late 2020) and there are no signs of voltage irregularities
Any suggestions on diagnostic tests I can perform to narrow the problem? Thanks!
Old Apr 30, 2021 | 03:05 PM
JagV8's Avatar
Maybe read the codes from the module?
Old Apr 30, 2021 | 03:09 PM
There are no odb2 codes. I don’t have a mechanism (that I’m aware of) to pull other code types.
Old Apr 30, 2021 | 03:28 PM
Sean W's Avatar
I think you'll need a cheap (all things relative) all purpose reader like Foxwell or icarsoft to read non engine codes.
Also, what is the battery voltage? I know I know and I read what you wrote. Check the voltage in the morning at the battery, not an OBD II reader. 12.6 volts minimum.
Alternatively, put a 10 amp charger on it, not a maintainer, or drive it to an auto parts stare and they will load test it at no cost.
Start with the easy stuff.
Old Apr 30, 2021 | 03:29 PM
Cee Jay's Avatar
Do a Hard Reset, then check it again afterwards.
Old May 1, 2021 | 01:14 AM
JagV8's Avatar
You're not looking for an OBD2 code - see the other posts.
Old May 1, 2021 | 06:55 AM
The battery with the car off was 12.7, with the engine running it was 14.2.
Old May 1, 2021 | 06:56 AM
I’ve done that a couple times, no change after the reset.
Old May 1, 2021 | 08:45 AM
Sean W's Avatar
Okay then - to my original comment - I think you'll need a cheap (all things relative) all purpose reader like Foxwell or icarsoft to read non engine codes. Sometimes auto parts stores have readers that will read non engine codes too (chassis, body, etc). Again, always worth it for me to save some $. Failing that, eBay or Amazon for a reader.
Old May 1, 2021 | 09:16 PM
jahummer's Avatar
I’ve had the same issue with mine for over a year. Likely the actuator has failed.
Old May 4, 2021 | 12:15 PM
gkubrak's Avatar
Same here. I could live with the dashboard msg, but now I'm at the point where it won't even retract after a battery reset.
And now I can't drive it without the dam sounder going off the whole time because it thinks the parking brake is engaged!!
I have an appointment with the dealer next week. We will see what they say, but most likely like Jahummer said, failed actuator.
A better code scanner will gives codes like C1801, which is what I'm getting.
You can check this bulletin too:
https://f01.justanswer.com/GAutoTech...B_Bulletin.pdf
Old May 4, 2021 | 12:22 PM
I ordered a 'better' scanner this weekend which should arrive tomorrow. So I'll likely narrow this problem further in the next couple days. I'm not looking forward to trying to replace the actuator if it ends up there :-(
Old May 5, 2021 | 05:03 PM
Seems to be the Hall Effect Sensor. So based on the diagnostics bulletin it’s either a wiring problem or the actuator needs replaced.
http://www.jagrepair.com/images/TSB/...ng%20Brake.pdf
Colin21958
Dec 3, 2022 11:25 AM
gkubrak
Dec 20, 2021 02:30 PM
‘Oleguy
Jan 18, 2019 08:00 AM
XJ8JR
Jan 29, 2016 06:44 AM
millenia man
Jan 29, 2011 05:06 PM
