rear license plate bulbs
Old Nov 1, 2020 | 04:37 PM
d a's Avatar
d a
Default rear license plate bulbs
1st dumb question for Nov 2020. Trying to change the bulb over my rear license plate but it won't release from the socket/fixture. I twist about a half turn and it comes out just a bit, but no further. Don't want to use force and brake the fixture (probably cost 1000 bucks to replace) so finally asking for help. I'm sure it's something simple. Thanks. (2010 XKR).
Old Nov 1, 2020 | 04:47 PM
Cee Jay's Avatar
Huh. Mine pulls right out without any twisting at all. Weird.
2010 XKR License Plate Bulb at AutoZone
Old Nov 1, 2020 | 06:07 PM
d a's Avatar
d a
Thanks. not sure what's happening but I'll keep at it.
Old Nov 1, 2020 | 06:11 PM
jbmi's Avatar
Spray a little Kroil in the socket then let it sit for awhile, sound like it needs a little lube.
Old Nov 7, 2020 | 04:42 PM
d a's Avatar
d a
Well after a little wd40 and time, a bit stronger tug got them out. Seems like a lot of heat is going on with these 194 bulbs. Maybe that's what held them in so tight. Anyway all is good now. Switched the 194s out for these LEDs on Amazon, they look good but time will tell if the change is good. Think I'll add just a touch of silicone to the O rings on install. Thanks for all the feedback.
Old Nov 7, 2020 | 05:00 PM
Cee Jay's Avatar
Did you slather on some Bulb Grease for next time? Course LED so probably no Next Time.
Old Nov 7, 2020 | 06:27 PM
fxdwg's Avatar
Don,
Did you see how much heat the led's generated by leaving them on for a bit before you buttoned her back up? The 194's generate a bunch of heat for their size. Some led's aren't much better.
Old Nov 7, 2020 | 06:43 PM
d a's Avatar
d a
Hadn't put it back together yet, but I'll check the heat before I do. Bulb grease?
Old Nov 7, 2020 | 08:09 PM
Cee Jay's Avatar
Originally Posted by d a
........................ Bulb grease?
Costs about a buck anna half for enough grease to do probably...... eight? bulbs sufficiently. It keeps corrosion from messing stuff up, therefore keeping installation and removal easy-peasey.
Old Nov 8, 2020 | 02:21 AM
peterv8's Avatar
I usually just put a thin layer of regular grease.:-)
Old Nov 8, 2020 | 02:10 PM
jons's Avatar
Bulb grease?
yes, it sounds like "headlight fluid" but actually is another term for dielectric grease.
Old Nov 8, 2020 | 04:34 PM
Cee Jay's Avatar
The store near me gives a pouch away with all bulb purchases, and one pouch usually lasts me quite awhile.
I also have a small can of Dielectric Grease somewhere.
OnlySlightlyEvil
Jul 18, 2020 05:52 PM
4x4uk
Nov 3, 2017 10:06 PM
nasomi
Nov 18, 2016 10:37 AM
bbbmesa
Apr 28, 2015 08:29 AM
thaclient
Nov 10, 2007 10:39 PM
