Touch screen not very bright
Old Jul 20, 2011 | 02:27 AM
sherbercars's Avatar
Default Touch screen not very bright
The touch screen on my new to me 08 xkr vert is not very bright ,I can not see it at all when the top is down and the sun is out and Im driving,I have to ask my wife to operate it, no,I have good eyesite, I have ajusted the brightness and dimmer up but no better,Is this a problem or is this the way they they are. BL
Old Jul 20, 2011 | 02:48 AM
Frog's Avatar
You will probably get a better response by posting your question in this section. We only know about the first generation XKR here. Touch screens are way too modern for us
Old Jul 20, 2011 | 03:28 AM
Cadillac's Avatar
Moved off to the proper area , thanks Frog for your input as well
Old Jul 20, 2011 | 05:57 AM
Stillwaters's Avatar
I have the 08 XK Convertible and have the same problem. No amount of adjustment makes the screen any easier to see with the top down and under bright sun. The screen is fine under any other condition and to be really fair, this problem is not unique to Jaguar. I used to use a Garmin GPS in my old Pontiac convertible and had the same problem. I just do not believe the current active matrix technology in LCD panels is quite up to taking on blazing sun shining right on it...
Old Jul 20, 2011 | 10:22 AM
TomServo's Avatar
My 08 is the same, as is the LCD screen on my 07 Z06, but GM repeates most of the data in the HUD which has to be one of the best automotive features ever designed/installed on a car.
Tom
Old Jul 21, 2011 | 12:20 AM
Thanks Guys
Old Jul 25, 2011 | 09:50 PM
GreyXK's Avatar
When the XK 150 premiered it was a not uncommon complaint in the automotive press.
I have an '07 XK coupe and pale coloration is a problem during the day, especially if the sun's reflected. A reflective ivory or caramel colored interior may also contribute to the problem.
Old Aug 4, 2011 | 12:30 AM
jimatvs's Avatar
Have you tried changing the background color of the LCD. There are two different colors. I have an 09 convertible and while it might get a little faint, there is never a time I can't see the text/display. Mine is set with the green coloring.
Old Aug 4, 2011 | 06:22 AM
How do you change the color scheme?
Old Aug 4, 2011 | 11:58 PM
jimatvs's Avatar
On the display, select Vehicle and on next screen select System Settings. Press the down arrow that appears at the bottom center left of the next screen. You should see two choices - a green-based and a blue-based display.
Hope this helps!
Old Aug 5, 2011 | 02:40 PM
GhostriderXKR08's Avatar
This must be a '09+ or '09 Portfolio+ option. Don't have the blue-base option in my '08 system settings. BTW...if you choose blue-base does your tach/speedo lights turn white or blue or is it still green....just curious.
Old Aug 6, 2011 | 03:20 PM
Stuart S's Avatar
Only the touch screen display color changes.
Finbarr1975
Sep 5, 2025 08:38 PM
jimforrest (uk)
Feb 28, 2019 06:42 PM
Finbarr1975
Oct 4, 2015 05:32 PM
10 XF Premium
Oct 2, 2015 09:22 PM
Glenn Barickman
Oct 1, 2015 04:09 PM
