Trim fastener removal - RESOLVED
Old Aug 23, 2022 | 01:23 PM
hafren's Avatar
Default Trim fastener removal - RESOLVED
Anyone know the secret in removing this style of trim fastener. Trim panel is situated above the brake pedal. I've tried prying out but it will break before detaching and tried pushing in on the center piece but it doesn't move?
Last edited by GGG; Aug 26, 2022 at 03:38 AM. Reason: Add "RESOLVED" to thread title
Old Aug 23, 2022 | 02:55 PM
lear60man's Avatar
Are you using a removal fork/prong tool? If so, pull harder and replace it if it breaks. Then show it who's the boss by saying 'I win' as you throw it in the bin.
Old Aug 23, 2022 | 03:23 PM
CurtJ's Avatar
You sure it isn't already broken? Looks like the base part of a push button trim clip, with the push button broken off -- the bit in the center is the remains of the push button shaft.
Old Aug 25, 2022 | 02:43 AM
+1
This type of trim clip:
The centre pin pushes in to LOCK and pulls out to UNLOCK. The clip is then pulled out with a forked trim tool.
Old Aug 25, 2022 | 08:47 AM
shemp's Avatar
To get it out, heat up the tip of a small long screw with a lighter. Then "screw" it into that center pin about 1/2 to 1 turn. It'll melt the plastic while it's getting screwed in. Let it cool and then pop it out.
YMMV, worked for me.
Old Aug 25, 2022 | 06:11 PM
hafren's Avatar
So after looking at the passenger side and JEPC I can see the po must have removed and replaced the trim panel with non Jaguar plastic trim fasteners. Well I managed to lever them out and as you can see they are xmas tree fasteners. Wanted to close out this thread with a solution should someone else find these installed.
Old Aug 26, 2022 | 03:40 AM
Originally Posted by hafren
..... Wanted to close out this thread with a solution should someone else find these installed.
Thanks for posting the solution to the conundrum. I've added "RESOLVED" to your thread title.
Old Aug 26, 2022 | 03:52 AM
JonWat's Avatar
No you haven't, OK now you have
OzXFR
Aug 16, 2023 08:47 PM
Guardian
Aug 30, 2021 08:45 AM
XJR033
Oct 16, 2018 05:45 AM
sanchez
XJ40 ( XJ81 )
Mar 20, 2018 06:26 AM
farkle-edina
May 24, 2016 10:46 AM
