Water from drain tubes??
Old Feb 28, 2019 | 06:52 PM
Kongo1's Avatar
Default Water from drain tubes??
Picked up my 2008 XK last week and I'm thrilled so far but I have my first newbie question...
Why when I'm only using heat and it's 35 F in PA am I seeing two little parallel puddles under the car at the back of the engine. Looks like condensation but not running A/C.
Old Feb 28, 2019 | 07:20 PM
Cee Jay's Avatar
The AC compressor runs pretty much constantly, although it's a variable unit and not a clutch-driven unit. It works to remove the humidity from the interior air so it will not condense on the interior of the windows.
Therefore, normal operation.
Old Feb 28, 2019 | 07:26 PM
Kongo1's Avatar
Thank you!!
Old Feb 28, 2019 | 07:52 PM
jagtoes's Avatar
If it's near the middle rear of the car it is usually condensation leaking out of the exhaust pipes where they connect. This will happen for a while until you burn the water vapors off with a little spirited driving. If the puddle is under the transmission then it is the AC drain.
Old Mar 1, 2019 | 01:25 PM
Ranchero50's Avatar
Yeah, if it's on both sides then exhaust drips. Not an issue. AC condensate runs onto the transmission about as far back as where the side vents are on the fenders.
Old Mar 1, 2019 | 07:16 PM
Kongo1's Avatar
It's on both sides so must be exhaust. Thanks guys!
Old Mar 2, 2019 | 06:31 AM
Kongo1's Avatar
Sorry I misunderstood, my little puddles aren't anywhere near the rear they are at the back of the engine. Must be what Cee Jay described.
Old Mar 2, 2019 | 11:35 AM
Cee Jay's Avatar
The duckie will drip onto the transmission and can go down both sides, hence parallel.
Old Mar 5, 2019 | 08:12 AM
hafren's Avatar
I'm with jagtoes and think its from the exhaust joints (not tailpipes) unless you confirm you find the drips after a period of driving (spiritedly - I don't know how long but say 20-30 mins)
Old Mar 5, 2019 | 08:44 AM
Sean W's Avatar
Take you HVAC system off the auto setting. Shut off A/C. Run the car and if you still have water dripping, it's likely condensation from the exhaust at the joints like Jagtoes and Hafren indicate. Happens to a lot of cars. If by turning off A/C, the water stops, then what Cee Jay said....
You leave it running in the garage and look under that car you can see it dripping from exhaust joints up at the mufflers.
Old Mar 5, 2019 | 07:05 PM
Kongo1's Avatar
Thanks all. Either way, being a new owner I'm just glad that it's condensation and isn't an issue.
Polyesterpig
Nov 18, 2015 07:20 PM
Dan Bennett
Jun 17, 2015 09:22 PM
Maninahat98
Jun 9, 2015 05:13 PM
larys192
Dec 21, 2014 04:35 AM
kyle04
Jan 22, 2014 01:14 PM
