What is this?
Old Jan 10, 2021 | 10:28 AM
Nookat's Avatar
Default What is this?
Hi
first time Jaguar owner and trying to learn as much as possible about the vehicle. Have a 4,2 n/a 2009 model year and try to figure out what this is as it has a small oil leak. Do I only need a seal or the hole part? Its a kind of a sensor, isn`t it?
This from the front of the left banks
Old Jan 10, 2021 | 10:30 AM
Nookat's Avatar
Its the one with the two wires if you wonder
Old Jan 10, 2021 | 10:44 AM
NBCat's Avatar
The wiring loom and connector are for the inlet camshaft variable valve timing (VVT) solenoid. There is also one on Bank1 as well.
Old Jan 10, 2021 | 11:16 AM
Nookat's Avatar
Aha, thanks NBCat👍🏻😊 Do you happen to know if I need the whole solenoid or just the seal?
Old Jan 10, 2021 | 12:51 PM
Cee Jay's Avatar
Someone asked this a few months ago, and I do believe they replaced the seal and everything was great.
Old Jan 10, 2021 | 12:58 PM
Stuart S's Avatar
https://www.jaguarforums.com/forum/x...estion-175691/
Old Jan 10, 2021 | 01:26 PM
Cee Jay's Avatar
Yeah, that one.
Dang, more than a year ago.
Course, "2020", so time is messed up anyway.
Old Jan 10, 2021 | 01:43 PM
Nookat's Avatar
Thanks fellows this is a great forum👍🏻😎
Old Jan 11, 2021 | 08:08 AM
guy's Avatar
guy
:-). Makes me happy to see others as discerning as many of us. Well done @Nookat !
Now go and replace that seal ;-)
Old Jan 11, 2021 | 08:36 AM
gkubrak's Avatar
At that age, its typical to leak like that. When it's time to replace the valve cover gaskets and clean out the oil separators inside them, then I'll worry about those seals.
I just spray it down with throttle body cleaner every now and then and its fine.
Old Jan 11, 2021 | 09:33 AM
Nookat's Avatar
You have a good point there gkubrak, I have cleaned the seal once and it seems that the leak is very little. Thanks again👍🏻😊
Old Jan 11, 2021 | 09:57 AM
NBCat's Avatar
You can replace just the seal. Squeeze the electrical connector and gently pull it back to allow the seal to be replaced.
Make sure the seal is fully seated into the opening on the cam cover then reconnect the electrical connector.
Old Jan 11, 2021 | 10:52 AM
Nookat's Avatar
I will do that NBCat 👍🏻😊
Old Jan 11, 2021 | 06:03 PM
forrestgk's Avatar
Default Seal replacement
It's a two minute fix, but take your time.
Just remove the connector - Squeeze and slide towards rear. It might seem tricky but try not to force and break it!
Ease out the old seal with a flat blade and slide all the way off the vvt actuator body.
Clean around the actuator body and the hole then slide on the new seal and push it all the way down all around until it's totally flush.
Refit the connector.
Here's a source for the replacement seal ...
2007 JAGUAR XK 4.2L V8 Variable Valve Timing (VVT) Solenoid Gasket | RockAuto
Old Jan 11, 2021 | 06:33 PM
Nookat's Avatar
Thanks fellows, the part is ordered👍🏻😊
Old Jan 12, 2021 | 02:35 AM
You have 2 posts in this thread that were automatically locked for moderation.
I couldn't see any problem with the text and it took a while to work out what was happening. It's the use of 2 emoticons together that causes the algorithm to block the post.
I've umlocked them now.
Brian123
Mar 2, 2020 07:02 AM
mscott
Mar 15, 2019 05:10 PM
jgonzalez2002
Jul 24, 2018 01:17 PM
ejjbee
Jul 12, 2018 08:07 AM
rf69
Jul 6, 2018 09:36 AM
