Is this ZF pan seal / gasket correct
Old Mar 5, 2018 | 10:40 AM
‘Oleguy's Avatar
Default Is this ZF pan seal / gasket correct
I purchased a new filter/pan off of EBay with oil and the pan has an o-ring type seal installed. Is this correct for my 2008 XKR Convertible?
Old Mar 5, 2018 | 11:18 AM
Sean W's Avatar
No luck on searching the pan # and the gasket number is all over the place with some sites saying it fits and some saying it doesn't.
Your transmission is ZF6HP26. If your eBay listing indicated it's for that transmission, you should be good to go.
Old Mar 5, 2018 | 12:36 PM
JackJohn's Avatar
That looks like the seal that was on the pan I bought and it worked correctly.
Old Mar 5, 2018 | 01:45 PM
Sean W's Avatar
Yep sorry. If the question was is this the right type of seal used on the ZF pan, then yes it is. I read the question as "did I buy the right pan/ gasket".
Old Mar 5, 2018 | 02:37 PM
‘Oleguy's Avatar
Thank you gentlemen for your reply’s. I had not seen a trans pan with an imbedded o ring seal before, always a gasket.
When I emailed seller he said if you want a gasket with the pan order ‘this one’ and gave me another listing.
I’ll use what I have. I was bit sckeptical so I also ordered a 26$ special order pan gasket from AUTOZONE.
It sounds as though I don’t need it.
Old Mar 5, 2018 | 03:05 PM
Sean W's Avatar
Correct Oleguy. No flat cork or paper gasket is used on the ZF transmission.
Old Mar 5, 2018 | 04:26 PM
mosesbotbol's Avatar
Did you buy the kit with fluid/pan/filter? I would be most concerned about the fluid as I read there is plenty of counterfeit ZF fluid on the market.
Old Mar 5, 2018 | 06:27 PM
‘Oleguy's Avatar
Yes I did buy the kit. Oil and pan. The meclotronic seal was seperate
Old Mar 5, 2018 | 07:09 PM
The seal came with the two kits I bought.
Andrew Fitch
Nov 20, 2016 09:02 AM
hoya_loya
May 27, 2015 08:50 PM
m1eckler
Feb 27, 2015 07:20 PM
BStopek
Mar 3, 2013 11:30 AM
dreamcar
Jul 19, 2010 11:01 AM
