1999 XK8 wont start
Hi Thermo,
Many thanks for the prompt reply,
I did push valve cap yet there are no gas coming off. Would Gas Filter have anything to do with this ? as I have recently replace gas filter,
This car is a 1999 Emerald Green XK8,
many thanks in advance for you help.
Victor Ngo
Victor Ngo
Victor, when I saw your description of an Emerald Green XK8, it reminded me of the old joke about the blonde who calls a mechanic up about her car:
Mechanic "so what's wrong with her?"
Blonde: "it wont start! It just makes a noise like my hair dryer."
Mechanic: "ok, what kind of car is it?"
Blonde: "it's a red car."
mechanic: "ooh, well ma'am them red cars are mighty expensive to fix, but then it's a good thing you called me. . ."
all kidding aside, it looks like your post might have lost its original thread or something? How can we help you mate?
John
John
Hi All,
Many thanks for the quick reaching out, my delay in reply have been the changes CoVid-19 have changes how to go about ways of our lives. Cut My Drama get to the point!!
I have a 1999 Jaguar XK8 Convertible V8 non turbo charge. has about 119K miles
I recently change the gas filter, and a tuneup with new coil and sparks, with new batteries.
But when I crank on it will not turn over, seems that gas is not getting there, I had ask Thermos from a 10 year old Thread because I was facing similar issue, and Thermos said to test the Gas Valve to see if any Gas comes out No Gas when I press the valve.
Can any one please help, I'm new to Jag Engineering, very much interested to learn this is why I bought this XK8
Thanks in advance all.
Do a search for "XK8 Bore wash"
Check and ensure your battery connections are on CLEAN and tight. Perhaps take them off again. Sand them down. Refit and try again. Id bet good money on those connections not being right.
Hi Bob,
Future can you suggest where I can get it to turnover? over the fuel pump you think is the main cause?
VN
VN
Bob G. I'm will yall but suggestively Mr Victor it's a good idea to hit the pump with an independent 12v source [**after pulling the connection to the car**] and make sure its the pump/ya hear it run- really quickly touch the leads Not prolonged... although a new fuel pump is a great idea on any vehicle with near 100k regardless.. Victor I assure you Bob knows his stuff to say the least I have spent an exuberant amount of time in the past few months reading the lions share of the threads on this forum. Seriously it always seems when anything technically inclined is being spoken of with carnal knowledge its men like Bob, avos, GGG. And a hand full of others that are spitting truth not regurgitated diatribe.. Best wishes on the repairs.. dont get discouraged you dont need a mechanic sir I promise with this forum and a basic set of tools you will definitely get that cat running propper..
Stay healthy
Stay healthy
Hi EnigmaX100R
Your message was very couraging, I think I will follow your advise.
Could you suggest and give me some instructions, like I mention i'm a new kid on the block and very little experience with mechanical of the Cat
This is a link to a video that will show you a simple method of getting to the pump and replacing it if necessary
the guys handle on YouTube is Sam1174
Most likely a member of this forum.. not sure though. You can do it Victor!!👊
Take your time and all will be fine! Think of all the loot you can spend on other things when you're not paying that mechanic to do it for ya my friend
Spray starting fluid into the air intake, and see if it fires. I've never had to do this on the Jag, but for most cars usually the air filter is a good access point to spray. If it fires, you are lacking fuel. If it doesn't, you are lacking spark. Fuel pump is a likely culprit if it's a fuel problem.
It's actually you're the man.
It's a contraction of you and are.
Your is possessive but don't listen to me because I am actually a high school dropout. (really)(I failed English and grammar classes due to lack of attendance)
Wise guy... now I know you're related to my mother at 42 years old I still can't speak proper English I spell phonetically and for some reason still use the word seen instead of I have seen or saw...
and it doesn't help I constantly use talk ti type, as a fat kid originally from long island new York my mouth full of marbles enunciation has me stumbling to sound as though I'm not uneducated.. hard to believe I'm sure but i hold a plethora of degrees, none of which are in English 🤐
I do still think as per jaguar's are concerned Youz da mang big guy-
Bob. Not to thread Jack Ol'victor here but I would love your outlook on my dual caliper conundrum.. I have another thread going title referring to controllable angles of yaw.. please chime in there if you get a minute to peruse over my rhetoric...
Good sir either way I appreciate your time. Thanks boss-
