Alternator replacement - how to remove the drive belt ?
Old Dec 10, 2012 | 12:42 PM
franksm's Avatar
Default Alternator replacement - how to remove the drive belt ?
Hi folks
Got the dreaded red-light on the dash this weekend - "BATTERY IS NOT CHARGING".
The battery is quite old, so replaced it with a fresh one (which solved som other issues) however the error message is still coming up when the engine is anything <1200rpm.
So, I have a new alternator on order. I have replaced these on other cars, the process is quite simple. But can anyone tell me what the procedure is to remove, replace and install a new drive belt ?
Good pics here, but no description: JagRepair.com - Jaguar Repair Information Resource
Frank
Old Dec 10, 2012 | 01:03 PM
Jag#4's Avatar
The belt comes off very easily. You will need a break over bar or long-handled socket drive. Put your socket on the nut for the tensioner (see the picture at the link you posted) and push the pulley to one side to relieve the tension on the belt. You can then slip it off the pulleys by hand.
Remove your socket and bar. The belt can then be removed from the engine bay. Replacement is the reverse of removal. Check the stickies for a diagram of the belt routing. (do this before removal and you will thank yourself later)
Old Dec 10, 2012 | 01:04 PM
jimbov8's Avatar
Franksm,
I have just looked in my manual, it may be the same for yours, and it says:
1. remove the engine cover
2. using a 3/8 inch square drive bar, rotate the accessory drive belt tensioner counter clockwise and detach the belt.
Hope this helps.
Old Dec 13, 2012 | 05:16 AM
franksm's Avatar
Thanks lads, just awaiting delivery of the replacement alternator now.
I guess the belt tensioner is a simple thing then, just spring-assisted tensioner, nothing more nothing less. The tensioner on other cars I have worked on has been the alternator itself, being mounted on a hinge of sorts.
Cant's wait to get the '8 back on the road, it's too icy and baltic here for the MX5 ;-)
Old Dec 13, 2012 | 05:28 AM
A picture paints a thousand words..........
Alternator replacement - how to remove the drive belt ?-v8-serpentine-belt.jpg
........... and no special Jaguar tool required!
Old Dec 16, 2012 | 02:14 PM
franksm's Avatar
Hi folks
Well, removing the drivebelt turned out to be ridiculously easy - the tensioner has enough movement in it, it really does just need pulled with a strong hand & spanner. Didn't even need to remove the fanpack, the top hose or anything other than the airbox.
Got the alternator out, it's just two bolts. However there's a plastic bush on the inboard side of the lower bolt that needed maneuvered around. Ended up levering the alternator out, it wasn't about to just 'fall out' once the bolts were removed.
The main worry was the electrical connector on the back of the alternator - the secondary one with two wires, not the main earth or 12V lines. The secondary connector was practically welded to the unit, and isn't in good condition internally as can be seen from my pic. I might look at splicing in a new one at some stage if I can identify an exact replacement.
In the meantime, still waiting for the replacement part, so fingers crossed it goes in okay.
Adding pics here anyway, as it might be handy for someone down the line. It's rare to see these alternators in the wild.
http://s192.beta.photobucket.com/use...Jag/alternator
Frank
front view of the alternator
rear view
rectifier board (or whatever it's called)
other side
board cover etc
brushes - these were uneven lengths on mine, dunno if that's normal
cleaned up
alternator with rectifier board removed
alternator bracket, bolt on top right, larger bolt on bottom with nut on the left, and earth bracket attached
Main +ve lead
secondary connector - looks badly worn on mine
Attached Thumbnails Alternator replacement - how to remove the drive belt ?-xl8alternator11_zpsb63986bc.jpg
Old Dec 16, 2012 | 07:18 PM
Jag#4's Avatar
Looks like you're well on your way. I also had to lever (pry) out my alternator. It was a PITA! Turns out that short bush inside the bottom mounting bracket was the issue. It had moved out maybe 1/16 of an inch...just enough to make the already snug ears catch hard.
Make sure you push this bush back in place before reinstall. It has to be flush. I think there is a diagram of this in the DIY section or maybe in the parts section.
Old Dec 17, 2012 | 04:03 PM
franksm's Avatar
Replacement unit arrived today - it was described on Ebay as a brand-new OE alternator, but half the price of the real Jaguar one. More expensive than a recon'd alternator but not hugely so.
Anyway, looks like it's the Nippondenso part but without tha 'Jaguar' badge. Pasting the info here in case anyone wants to go this route with a Denso supplier in future
Attached Thumbnails Alternator replacement - how to remove the drive belt ?-img_1579_zps5d8dad2c.jpg   Alternator replacement - how to remove the drive belt ?-img_1580_zpsb9baf7ab.jpg   Alternator replacement - how to remove the drive belt ?-img_1581_zpsbd2accb1.jpg
Old Dec 17, 2012 | 07:27 PM
Gus's Avatar
Gus
You needed to look a little harder on my page
Originally Posted by franksm
Hi folks
Frank
Old Dec 21, 2012 | 03:12 PM
franksm's Avatar
Got the new alternator in today, it's all fine and the car (and me) are happy once again. Putting the drivebelt on was a complete nonissue, there's tons of travel in the tensioner once you have a lever on it.
Thanks for the help and moral support, all !
Attached Thumbnails Alternator replacement - how to remove the drive belt ?-img_1587_zpsa40524d5.jpg
Old Sep 15, 2014 | 06:51 PM
protech's Avatar
Gus
On an 02 XJR just how did you get the top bolt out, tired a universal but can't get the right angle, I can get a 10mm gear wrench but there's not enough of an arc to make do.
Any advice?
thanks
Old Aug 14, 2015 | 11:59 AM
looops's Avatar
Waking a really old thread but has anyone tried replacing just the rectifier? REGULATORS FOR DENSO ALTERNATORS
Old Aug 15, 2015 | 04:52 AM
toaster's Avatar
One question after viewing the photos:
where is the suppression module?
Old May 20, 2018 | 11:04 PM
Busyb187's Avatar
Hi folks
Frank
rear view
other side
board cover etc
cleaned up
Main +ve lead
I need to replace my alternator on my 2007 XKR but they want an arm and q leg to do it so I was planning on doing it myself. Ive looked here but cant seem to find the procedure. Ive heard its impossible to remove without taking fan, mounts and bottom cover off. Since youve done it was wondering if you can elavorate on this and any suggestions or pointers will be greatly appreciated.
Old May 21, 2018 | 11:23 AM
Gus's Avatar
Gus
See the link on post #9 My error you need a procedure for a 2007
Old Aug 29, 2020 | 01:02 AM
rf69's Avatar
Hello
I am trying to replace the alternator in my jaguar 2004 XJ8. Stopped charging the battery. I am wondering if it is a difficult task.
any advise please
Thank you
Old Aug 29, 2020 | 01:08 AM
rf69's Avatar
Hello
any advise please
Thank you
Old Aug 29, 2020 | 01:22 AM
rf69's Avatar
Hello
any advise please
Thank you
Old Aug 29, 2020 | 05:31 PM
labcoatguy's Avatar
You're in the wrong forum for a 2004 XJ8. You want the X350 subforum.https://www.jaguarforums.com/forum/x...-x350-x358-28/
BrentGardner
29
Dec 16, 2024 12:13 AM
Isoruku
Jun 19, 2020 12:54 PM
RaceDiagnostics
Dec 11, 2015 10:12 AM
peterg19
Aug 30, 2015 08:48 AM
perfectphoto
Aug 29, 2015 10:11 PM
