Well, this may not really belong here, but I do get a bit envious when I read about all you young guys ripping out engines and transmissions and tackling major projects. At 80+ I have to be happy with smaller tasks, like transmission and engine oil changes, a water pump here and there. Brakes, bearings and smaller stuff like that...... Oh, I did do the Green Shower thing too.
However, I was also young once. My first car was a French Dyna Panhard, straight from the junk yard.....
A crazy two cylinder boxer with a common torsion rod for both intake and outlet valves instead of valve springs. Low inertia and happy to rev.
Made one heck of a racket when the rod broke though! You can see the rod housing on top at the end of each cylinder
A drop tank from an old de Havilland Vampire or Venom cut into quarters became the fenders. A few pieces of
aluminum sheet filled the void in between
A coat of paint, probably sprayed out of the back end of a vacuum cleaner, completed the job. Eventually
it also got a wind shield - the rear window from a old Saab 96.
Those were days when we were just dreaming of owing a Jaguar. When all a car needed was air, fuel and spark to run.
Memories😊
..... drop tank from an old de Havilland Vampire or Venom cut into quarters became the fenders. A few pieces of aluminum sheet filled the void in between .....Those were days when we were just dreaming of owing a Jaguar. When all a car needed was air, fuel and spark to run. .....
Very inventive. I wonder how much the Air Force paid for drop tanks. It was probably a very expensive car.
Sadly, in the near future all a car is going to need is a battery. I'm really not looking forward to that.
Interesting bit of history, but...... I loved the S-Type design, so I bought one in 2000. Had a constant flow of mx. problems with it from day one. Elect. windows stopping, usually down Told by dealer that Jag knew about the problem as a defect, but would only change windows when they failed. Fuel pump failure, w/s/ wipers failing...
Loved the looks, hated the operation.
I do understand that the dash on the XK is an exact duplicate of the Spitfire's wind??
So far, my '06 XK, 94K miles is more dependable that my S-Type.
