brake booster vacuum line replacement?
Old Nov 27, 2016 | 12:25 PM
Forceofhabit's Avatar
Default brake booster vacuum line replacement?
Hi guys..... in need of help!
I replaced my brake booster in my 2000 xk8... no problems except my vacuum line is leaking and i cant find where it goes to the intake to replace? And what do i need to remove prior???
Old Nov 28, 2016 | 12:12 PM
Don B's Avatar
forceofhabit,
I have moved your post from the forum for the XJ40 to the forum for the X100, which is the Jaguar factory project code for your 2000 XK8. Here you will find knowledgeable owners of similar cars.
Cheers,
Don
Old Nov 29, 2016 | 07:07 AM
RaceDiagnostics's Avatar
It attaches here, just below the throttle body.
Also order one of these Jaguar
Jaguar BRAKE BOOSTER VACUUM HOSE CONNECTOR KIT - C2S15816
Fitting it was tricky, I managed to lose an o-ring into the intake manifold.
Old Nov 29, 2016 | 12:36 PM
kstevusa's Avatar
Looking at SNG diagram, is this a 2 piece pipe? There is a brake vacuum pipe and a vacuum pipe. which one connected to the T/B? The same situation shows up on the 2003 fwd. There is a Brake vac. and a Vac. pipe. Which part # would one order or what is the Vacuum pipe only? The connector kit sounds good, but which pipe to order is the question. Hopefully there is only one (1) pipe going to the booster and it has a ck valve?
Old Nov 29, 2016 | 06:23 PM
The pipe I show is parts 13/20 from the SNG catalog, it goes from the inlet manifold to the bulkhead of the compartment that the brake booster is in, it does not go directly to the brake booster. At the bulkhead it connects to the end of part 9/22.
The sng pic of 9/22 is not very good, here is a better one I found on line.
Old Nov 30, 2016 | 06:46 AM
kstevusa's Avatar
Thanks for help, I can tell that they are a 2 piece set. 1 from T/B and another up to the booster from the bulkhead .
Old Oct 17, 2022 | 04:19 PM
jaguar4.2's Avatar
Default vauum kit will this kit fit a xk8
hi do you know if this kit will fit a xk8 manifold
Old Oct 17, 2022 | 04:28 PM
jagbits's Avatar
Former Sponsor
No it will not the correct one is no longer available new we have a good used one:
https://www.jagbits.com/product/MJA5910BC-USED.html
Old Oct 17, 2022 | 04:42 PM
jaguar4.2's Avatar
hi
its not the pipe am after its the small brass kit that fits
in the manifol
cheers
Old Oct 18, 2022 | 03:12 AM
michaelh's Avatar
Yes it's available either frrom a dealer or SNG Barratt.
There's no need to replace the brass ferrule, just the 'O' ring and plastic locking insert.
03 XKR
Oct 11, 2016 12:40 AM
Asdrewq
Oct 9, 2016 09:45 AM
97 Xk8 mayhem
Oct 8, 2016 01:27 AM
scottpix
Oct 5, 2016 02:18 PM
Eskr
Oct 4, 2016 11:42 AM
