Can't remove hose clamp - resolved
Old Feb 13, 2016 | 10:31 AM
giandanielxk8's Avatar
Default Can't remove hose clamp - resolved
I'm in the process if replacing the low pressure power steering house that goes from the reservoir to the pump and the clamp that secures the house to the pump had me completely stymied. I can't get it off. The clamp is right under the left valve cover and is connected in such a way that I have to pull upwards to remove it with my channel lock wrench. The space to do so is so tight and uncomfortable that I can't get the clamp to budge.
I already disconnected the hose from the reservoir side without much of a problem. That old hose is so damn toasted that I can't pull on it while holding the clamp open. Anyone got any advice?
Old Feb 13, 2016 | 01:40 PM
I've tried all day, even got a pair of 90° pliers but I still can't get that ******* out!
Old Feb 13, 2016 | 06:08 PM
Squeeze the two lugs together with a plumber's wrench and slide the clip back along the hose until it's clear of the pump outlet.
This tool is a lot easier for Jaguar hose clips than pliers.
Old Feb 13, 2016 | 06:18 PM
motorcarman's Avatar
You need to have SEVERAL types of hose clamp pliers or you will always be at a disadvantage!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Astro Pneumatic 9409ACA Cable For 9409A Hose Clamp Pliers - Part
Look at Cable Type Hose Clamp Pliers.
bob
Old Feb 13, 2016 | 07:19 PM
Dr. D's Avatar
I can appreciate using proper tools, however this looks like a challenge. Me against machine using only what I have. Which is the most tenacious? Come on, I cannot be the only one with this mentality!
Maybe a flat blade screwdriver prying on the end of the hose to push it off while opening the clamp with pliers.
Or maybe a small C clamp, or nut and bolt with two larger washers to hold it open.
Air tool with small cutoff tool.
Bend or break off that tang so that the clamp will open farther.
Whittle the hose out from under the clamp.
Anything, just keep your composure, and don't give up.
Although I cannot really tell by the photo, know that I really do believe you can win this challenge, and can share your accomplishment when you finally say
"YES"!
Old Feb 13, 2016 | 08:39 PM
I finally got it done a few hours ago. I used a combination of pliers, knife, channel locking wrench and extensive creativing cursing to get it done.
Got the clamp out after 6+ hours and the new hose with clamps in after 8 minutes. I refilled the oil and voila! No more leak.
Now I'm left with busted knuckles, sore fingers, and a painful back. I'm glad I'm only 22; the pain will be gone tomorrow.
Old Feb 14, 2016 | 01:23 PM
tommytess's Avatar
Well done you.
Tommy
Old Feb 14, 2016 | 08:50 PM
stevepaa's Avatar
bob
This is the one i have used extensively on the xk8. Don't know how I could have gotten some of them off without it.
Old Feb 15, 2016 | 04:16 AM
Originally Posted by giandanielxk8
I finally got it done a few hours ago.....
Good to hear you beat it.
I have the same symptoms but at three times your age the pain won't be gone tomorrow.
Old Feb 15, 2016 | 07:20 AM
Hahaha, yeah... The scab on my knuckles still hurts.
molotov369
Mar 18, 2016 10:27 PM
jagtoes
Feb 18, 2016 01:46 AM
NorJag
Feb 15, 2016 06:58 AM
ianw48
Feb 15, 2016 04:19 AM
Mr G
Feb 12, 2016 01:49 PM
