Comprehensive Component Monitor Test
Old Oct 12, 2024 | 07:46 PM
Alan-2002XKR's Avatar
Default Comprehensive Component Monitor Test
I bought my 2002 Jaguar XKR a few months back knowing that it had failed smog check.
I have fixed all the problems I can find and currently had MIL off and no DTC but the Comprehensive Component Test always fails.
The one that always fails is Manufacturer Defined Test ID #0A and I am not sure what that means.
After searching everywhere, I found a reference in the document AJ27_EMS_OBDII.pdf
It says Test ID $0A is for EGR Flow Malfunction, but my EGR test has always passed so I don't think it is that.
Can anyone offer any advice on this issue?
Old Oct 13, 2024 | 07:42 AM
Jon89's Avatar
My wife's car is a 2006 XK8. Here is how I get the Comprehensive Component Monitor to clear:
- Fuel level in the tank must be between 30% and 85%.
- Start engine from cold, idle engine for more than 12 minutes 45 seconds.
- Drive away and maintain a road speed between 8 mph and 80 mph for at least 50 seconds.
- Pull over and idle engine for at least 66 seconds.
This procedure has worked for me since I discovered it on my JTIS CD back in 2020....
Old Oct 13, 2024 | 02:23 PM
Default Thanks for the reply.
I will try that and let you know what happens.
Many Thanks.
Old Oct 15, 2024 | 05:01 PM
Default Possible ECM repair.
Jon89 - I ran the drive cycle recommended for your 2006 XK8 but it did not work on my 2002 XKR.
The JITS for 2002 says that they had not developed a specific drive cycle for the Comprehensive Component Monitor, but I thought it was worth a try anyway.
I am starting to suspect a problem with the ECM itself and looking at repair or reconditioning options.
I don't know how to test the ECM so I guess I just have to send it off to the experts for repair.
Any advice would be appreciated, as always.
Thanks,
Alan.
Old Oct 17, 2024 | 03:13 PM
JagV8's Avatar
I was thinking it might be the attached but the MY may be wrong.
Old Oct 18, 2024 | 06:56 PM
Thanks, JAGV8 as that was helpful.
My car has passed EVAP and the other tests except the Comprehensive Component Monitor.
I thought it relied on completion of the other tests, but it appears to be more than that.
Quote: the comp components monitor readiness is tied to essentially every diagnostic that is NOT in the other monitors.
So I believe I have one component issue that is preventing completion for smog readiness.
Old Oct 19, 2024 | 02:12 PM
Xman's Avatar
Hey Alan, good luck! Have a similar issue with my 2004 XKR for "comprehensive component" IM readiness as being "inc" for GA emissions. Seems like a catch22 as I have seen all pass, then engine light will come on with a P0456 code (very small leak). I'll try again with the above PDF steps, although suspect next stop is auto repair visit to check with smoke test and possible cannister, and/or other issue for the EVAP leak to resolve. Have already replaced the gas cap. Urgh...so close to being ready
Old Oct 19, 2024 | 11:18 PM
Default Recurring DTC problems
Hi Xman. I have similar problems with recurring codes, so here is my experience for what it's worth.
On my 2002 XKR, the issue was code P0447 Canister Close Valve CCV open circuit.
I checked it myself and could not find a problems with the CCV so I took it to a Jaguar independent specialist.
He found no problem either but advised to replace the CCV anyway. Parts and Labor $300.
Code P0447 came right back. I checked it again and found no problem.
Then I found a technical bulletin that said for code P0447, to check the purge control valve even if the DTC for it is not flagged.
So I checked mine and it was stuck closed, would not operate. I replaced it myself. Jaguar part $155 + tax.
Code P0447 came right back. I checked CCV and all the circuits over and over but found no problem.
Could be electrical connectors or computer issues, but I noticed something interesting ......
I was often reading the DTC status with ignition on engine off (IOEO) and that seemed to cause a problem.
The code P0447 would only flag with engine off and not with engine on.
I think the computer turns off some stuff if ignition is on more than 5 seconds without starting the engine. (my theory)
Since then I always start the engine immediately and never use IOEO ignition position.
The code P0447 never came back again and my EVAP system passed the monitor tests.
Also, I often get code P1647 for a faulty connection to O2 sensor B2S1 so I fiddle with the connector and code goes away for a while.
All 4 of the O2 sensors were replaced so I think it is just a connector issue on that one.
Your mileage may vary, but I hope that helps.
Regards,
Alan.
gijoe50000
Jan 24, 2023 08:10 PM
gijoe50000
Aug 28, 2022 02:46 PM
Johnny_B
Jun 17, 2020 02:09 AM
dtrain
XJ40 ( XJ81 )
Oct 28, 2012 09:03 PM
