Dent removal
Old Dec 11, 2018 | 02:00 PM
Default Dent removal
Where most of us would think a new panel was the only solution, Ralf Rathmann demonstrates what can be done for a damaged XK8 with simple tools and a lot of skill:
Old Dec 11, 2018 | 04:08 PM
cjd777's Avatar
Sorry Graham, didn't work for me.
Love to see how different approaches get the same results. Hope it's easier than what I do. LOL
Old Dec 11, 2018 | 04:26 PM
michaelh's Avatar
Link is dud
Try this:
Old Dec 11, 2018 | 04:51 PM
michaelh's Avatar
Thanks, Graham.
Makes it look sooo easy..
Old Dec 11, 2018 | 05:30 PM
I was expecting the dent to come out but not such a good job that it didn't need filler!
Old Dec 12, 2018 | 02:50 AM
cjd777's Avatar
Thanks Graham, that was a treat.
Old Dec 13, 2018 | 07:38 AM
MiragePro's Avatar
It sure beats using a plunger and a hammer. Bet the tools he is using are not found at Harbor Freight.
Old Dec 13, 2018 | 08:22 AM
Originally Posted by MiragePro
..... Bet the tools he is using are not found at Harbor Freight.
Perhaps not HARBOR FREIGHT but they are to be found at HARBOR STREET, St Rafael, CA:
https://advcrs.com/products/miracle-system-wagon/
None of the distributors are posting prices on their websites - I expect this kit could make Snap-on look cheap.
Old Dec 13, 2018 | 09:47 AM
Jon89's Avatar
I would like to know how much time was required in order to achieve what looks to be an outstanding result....
Old Dec 13, 2018 | 10:06 PM
Burnham's Avatar
I had a couple of significantly less serious dents, but still huge cosmetic flaws, removed by PDR (paintless dent repair) method by a true artist here in Portland, OR. Spent $175 dollars and a couple of hours watching...probably a couple of thousand dollars if not more, if repaired conventionally.
That was beautiful work in the vid, top class.
Old Dec 13, 2018 | 10:30 PM
bcprice36's Avatar
Cool Paintless Dent Removal...
A couple years ago someone dented my Left Rear Fender just behind and below the Gas-Cap door; not as big an area as in this You Tube story....A guy that works for BMW told me to call this Guy, who does Paint-less Body work.. I met him at the BMW Dealer down the Street and we parked back in the Parking lot. He opened the Trunk /Boot and got some tools out of his Pickup....The first thing he did was to push the Fender out from the inside and then went to work with his tools....Within 15 minutes he had the darn thing straighten out and smooth as a Baby's Butt!....No painting had to be done.....I gave him 3 twenty's. He smiled, I smiled back and we both drove off...…………He said it was an easy job as he could get in behind the Dent through the Trunk....If it had been a door, Sometimes he might have had to take the door liner off …..More time consuming the larger the Dent....
Billy Clyde in Houston
All youcan see is the Clouds!
Old Dec 14, 2018 | 05:04 PM
Chuck Schexnayder's Avatar
GGG,
That's not exactly what I would call a "dent".
A dent to me would be what some ---hole left you in a parking lot when they opened their damn door. :-)).
Chuck
Old Dec 18, 2018 | 07:37 AM
Originally Posted by Chuck Schexnayder
GGG,
Chuck
The small scale, low cost DIY version works well for those "trolley kisses"!
Old Dec 18, 2018 | 09:34 AM
mhminnich's Avatar
I removed a large dent from my front fender using that harbor freight glue tab puller. Using a slide hammer with the glue tabs worked like a charm.
One caution is the very small feet on the crossbar. You can add twice as many dents as you pull if you aren't careful.
Old Dec 18, 2018 | 01:19 PM
Grybrd's Avatar
Paintless Dent Repair when done correctly is well worth a try. One of my cars was gently side-swiped and damage to the front fender included dents right on the body line over the wheel well.
$200 later and in any light, at any angle, it is spot-on.The lady who hit me was very glad to pay for it vs. a fender repair and fender and door repaint.
As a result of the same event I had to have wheel repaired vs. replacement. Superb results.
Old Dec 18, 2018 | 03:05 PM
Jon89's Avatar
The best PDR gurus are indeed worth the time, money, and effort involved....
Old Dec 9, 2022 | 08:10 AM
enthusiast11's Avatar
That's really cheap compared to the prices I have quoted here for conventional dent repair, I have to look for pdr removal now.
avus9
Mar 23, 2019 11:45 PM
ChristianXJ
Oct 25, 2013 09:06 AM
Jaggyx
Sep 18, 2011 12:42 PM
haroldleggett
25
Jan 11, 2011 10:53 PM
