Do I need to lube o'rings on injectors before installing?
Old Nov 6, 2014 | 09:27 AM
brgjag's Avatar
Default Do I need to lube o'rings on injectors before installing?
I got my fuel rails and injectors back from Injector RX, they capped my pulsation dampeners and cleaned up my injectors and put all new o'rings on them. Do I need to lube the o'rings at all and if so with what before I pop them back in the rail and into the intake???
Old Nov 6, 2014 | 11:04 AM
aode06's Avatar
YES
or bust open an expensive fuel injector , use hand lotion, preferably with cocoa butter
Old Nov 6, 2014 | 11:14 AM
brgjag's Avatar
so I can use a hand lotion on the rings, more or less to keep them from getting torn up if I put them in dry?
Old Nov 6, 2014 | 02:40 PM
ccfulton's Avatar
I used a little dab of motor oil when I did mine.
Old Nov 6, 2014 | 04:53 PM
stevepaa's Avatar
i use 3m o-ring grease or vasoline. use either very lightly, the lube helps the o-ring move under pressure to its sealing position where it then is compressed by the pressure fluid and then seals. too much lube and the lube might provide a passage for the presseurized fluid.
Old Nov 6, 2014 | 05:29 PM
Brutal's Avatar
Yes and use 3m silicone paste. Always always always or you risk cutting a seal. I dont like petroleum based as could cause issue with different seal materials
Old Nov 6, 2014 | 06:25 PM
brgjag's Avatar
well reading it here and Googled it, I used a motor oil. I guess we will see it it leaks. I have already mounted them into the rails and clipped them in. Tommorrow or this weekend I will button it all back up and hope the hell all the work I have done to the car (my other threads) that she will fire up and run.
Old Nov 6, 2014 | 07:04 PM
ccfulton's Avatar
I would hope that orings meant for use with gasoline don't have a problem with petroleum derivatives.
But it's true, silicone is probably the safest for all types of seal materials.
Old Nov 6, 2014 | 07:17 PM
brgjag's Avatar
I did more searching, there is all types of input to what lube to use and motor oil is often given as the way to lube them as stated on many other car forum sites.
Old Nov 6, 2014 | 10:59 PM
plums's Avatar
Of course there is always the option of referring to JTIS.
Old Nov 7, 2014 | 06:47 AM
ccfulton's Avatar
Where is the fun in reading the proper instructions?
Old Nov 7, 2014 | 08:39 AM
brgjag's Avatar
which says? I do not have that.
Old Nov 7, 2014 | 06:19 PM
ccfulton's Avatar
Here you go:
Injector_Installation.pdf
If you will be working on the car regularly JTIS is a handy tool to have:
https://www.jaguarforums.com/forum/g...rchives-65926/
Old Nov 7, 2014 | 07:33 PM
brgjag's Avatar
well the rail is in, car runnning, no leaks yet other then fuel pressure regulator I did not get a new one or new orings and after a few minutes running it started dripping so I shut it off. Can I find the orings for that or buy the whole unit??? It is a ford part on mine.
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
mrplow58
Jan 21, 2024 05:53 AM
mrplow58
Sep 15, 2015 09:58 PM
Bcrary3
Sep 11, 2015 10:36 AM
