dumb remote battery question
Old Jan 27, 2011 | 09:29 PM
smokphattys's Avatar
Default dumb remote battery question
This question probably sounds dumb but my remote only works when im close to the car, i figured the battery was dead but when i opened the fob there were 2 batteries stacked on top of each other. is this right? can someone verify the size/style battery required? I drive a 97 xk8
thanks
Old Jan 27, 2011 | 11:18 PM
turbo68's Avatar
I believe it is CR2016 battery.
Old Jan 28, 2011 | 08:06 AM
so theres supposed to be 2 stacked on top of each other?
Old Jan 28, 2011 | 09:55 AM
Martin's Avatar
Yes the batteries are stacked. You don't often see batteries used in series but these are.
Old Jan 28, 2011 | 10:33 AM
ok thanks
Old Jan 28, 2011 | 11:29 AM
newboy's Avatar
.....following on from this point.
how long have you got from when you open the key to take the old batteries out and replace them with new ones before the key needs to be reprogrammed?
or will the key work straight away when you put it back together or do you have to reprogram it the moment the batteries are taken out?
Old Jan 28, 2011 | 03:09 PM
turbo68's Avatar
Sorry that i didn't put in that you needed 2 earlier... ! Brain was tired... but I changed my batteries recently and had no problem with using it without going thru the programming. Although, there is program instructions in the forums and it was not hard to do.
Old Jan 29, 2011 | 09:34 AM
i think you have to change the batteries within 20 seconds, otherwise you will have to reprogram the remote
Old Jan 29, 2011 | 04:57 PM
Martin's Avatar
I changed the battries in both my fob's and they were off long enough to clean the switch contacts. I didn't need to reprogram. It has been my experiance that these Jaguar fob's aren't as long distance as I am used too in my other vehicles
Forcedair1
Sep 8, 2025 01:57 PM
Dagny
Jun 11, 2024 01:06 PM
mbergen
Oct 23, 2019 10:26 PM
mrplow58
Sep 9, 2015 11:27 AM
DEklof
Sep 8, 2015 05:28 PM
