Engine failsafe problem
Old Feb 22, 2016 | 04:12 PM
02jagstype's Avatar
Default Engine failsafe problem
Hello, I have a 98 xk8 that is randomly popping up the engine failsafe and amber light. It will happen with or without cruise on and it only flashes on for a split second. Usually happens at mid throttle or when getting up to highway speeds, dosent effect anything it just flashes on for a sec or more then goes right out. I have no check lights and I removed and cleaned the brake pedal switch. Any ideas on what I should try? Thanks in advance
Old Feb 22, 2016 | 04:24 PM
DaveInVA's Avatar
Might have a flakey TPS...
Dave
Old Feb 22, 2016 | 05:31 PM
02jagstype's Avatar
Thanks, I will check the connection on it and see how that is.
Old Feb 22, 2016 | 08:01 PM
Gus's Avatar
Gus
Hard to say what is going on. It could be a number of things from the throttle body to a faulty knock sensor among other things. Check for any codes and if you can plug an OBDII code reader in and drive the car and see if it captures the code then post that code.
Old Feb 22, 2016 | 08:09 PM
02jagstype's Avatar
Thanks, it was hard for me to figure out where to start but after your advice I plan to purchase the Bluetooth odb2 reader and I will see if I can capture a code at the time it happens.the engine failsafe only comes on long enough for me to read it and then it's gone and no check lights appear or stay on dash. I haven't replaced the brake switch but that was the first thing I removed and cleaned and tested. Cruise works fine and brake lights are working so I think I can rule that out at least.
Old Feb 22, 2016 | 08:20 PM
Gus's Avatar
Gus
See if you can capture the code first.
Old Feb 22, 2016 | 08:25 PM
02jagstype's Avatar
Thanks again I will try that as soon as scanner arrives.
Old Feb 23, 2016 | 01:57 AM
JagV8's Avatar
It can even be a battery on its way out.
You may have a pending code. Doesn't matter when you read it - any time at all will do, parked or whatever.
Old Feb 23, 2016 | 12:42 PM
02jagstype's Avatar
I have a pending code p1111
Old Feb 23, 2016 | 12:51 PM
Jon89's Avatar
P1111 means that all monitors have completed their tests with no errors found....
Old Feb 23, 2016 | 02:09 PM
Gus's Avatar
Gus
See if that is all you get when you drive the car and you get the failsafe flag.
Old Feb 23, 2016 | 02:30 PM
Rick L's Avatar
P1111 is the only code that doesn't mean "Send Money"
Old Feb 23, 2016 | 02:38 PM
02jagstype's Avatar
Thanks again for all the help, when the Bluetooth scanner arrives I will see if I can get a code as it happens.
Old Feb 24, 2016 | 02:47 AM
JagV8's Avatar
It's unlikely in the extreme, for it would be kept (at least as a pending code).
Old Feb 24, 2016 | 05:38 AM
jamdmyers's Avatar
A quick look at the JTIS for your MY provides a subset of codes that only occur with FailSafe and AMBER light, the default mode is Cruise Inhibited for all, and as follows:
P1516/P1517/P1571/P1697/P1696/P0566/P0567/P0568/P0569/P0570/
You might review what these indicate to help with your investigation.
NathanDD6
Jun 1, 2024 11:43 PM
agentorange
Apr 16, 2022 09:04 PM
ChuckR
Apr 3, 2016 11:23 AM
roberthornsey
Feb 11, 2016 05:41 PM
sweatyfox
Feb 10, 2016 10:20 AM
