Failsafe Engine Mode question
Old Nov 7, 2022 | 04:16 PM
Snackalac's Avatar
Default Failsafe Engine Mode question
When I start up my 2000 XKR, about a third of the time the “Failsafe Engine Mode” message will appear on my dash for literally less than a second immediately after ignition, but then disappears. It’s never lasted more than 1 second. Is this normal or should I get it checked out? There’s no engine lights on.
Old Nov 7, 2022 | 05:17 PM
motorcarman's Avatar
I get a TRACTION CONTROL FAIL or other messages when one of my X100 or X308 sedans sit and the battery gets a little low.
Try looking for PENDING CODES if you have a DTC reader with that capability?
Old Nov 7, 2022 | 09:02 PM
Snackalac's Avatar
Hi motorcarman, I don't have a DTC reader, are you able to reccomend one?
Old Nov 8, 2022 | 09:08 AM
OBDII code readers can be found at auto part stores, Amazon, eBay etc.
Cost is $20 on up.
Many have a feature that can read PENDING CODES.
Old Nov 8, 2022 | 02:09 PM
Snackalac's Avatar
Any idea if I would need a scanner that reads jaguar-specific codes for this type of problem, or would a generic scanner probably work?
People seem to reccomend the Innova brand. Seems that it will show pending codes, according to one reply about the product.
Old Nov 8, 2022 | 02:37 PM
ALL OBDII code readers can communicate with the ECM.
IF you want to communicate with all the other Control Modules, then a Jaguar specific reader would be needed.
Old Nov 9, 2022 | 08:20 AM
JimmyL's Avatar
Check out this sticky on OBDII readers -
OBDII Code Scanners ** Member Approved ** - Jaguar Forums - Jaguar Enthusiasts Forum
Old Nov 9, 2022 | 10:04 PM
Johnken's Avatar
Snack, just remember: while the reader will display the correct alpha numeric fault code, IME its rare that the English description shown on the reader is correct.
Iow, copy the code down, look it up. We have references on here. Or just Google 2003 jaguar xk8 code (number) . . .
Might save you time and headaches.
John
Old Nov 10, 2022 | 08:24 AM
And remember, P1111 is NOT Mass Airflow Fault!!!!!!!!!!!!!!!!!!!
Cathead
Feb 20, 2022 02:40 AM
smtguy
May 14, 2013 08:12 AM
stevehill
Oct 26, 2012 10:01 PM
djsomebody
Jul 18, 2011 08:16 PM
