Which fob ??
Old Mar 5, 2016 | 03:26 PM
dr.fixit's Avatar
Default Which fob ??
I know there are more than one model of remote fobs available for the XK8. Can I tell which one I need by the VIN? I tried asking the parts guy at the local Jag dealer, but he wouldn't tell me. A real d*ck .
Old Mar 5, 2016 | 04:14 PM
Ungn's Avatar
I'm afraid you need the "expensive" one. LJA2610aa
The later models are much more plentiful and much cheaper.
I'm in the same boat, since I have a 16 year old kid, it's only a matter of time I'll need a spare.
Old Mar 5, 2016 | 08:35 PM
stevepaa's Avatar
many fobs will work, you can use a flip key fob from other style jaguars just for the fob functions and just remove the key.
Old Mar 5, 2016 | 08:52 PM
Ungn's Avatar
That would be great if true. What other FOB's are 315mhz?
None of the XJ S-type XJR, etc 315mhz Key FOB's list XK8 as compatible.
I guess the Transponder Key isn't compatible, but the remote still works?
Old Mar 5, 2016 | 11:24 PM
JBzXJ40's Avatar
From my understanding the NAS market, only,uses 315hz. What exactly are you trying to achieve, replace a remote that isn't working, or getting a new one. As far as the keys go, even though they may be the same frequency, I don't think you can interchange keys from one model to the next. The early XK or X100, can't interchange with an S-type. Now the XJ350, late model S-Type and X-Type basically use the same key transponder and remote, and can program one to the other. Given that you have an early XK, you can't interchange.
Old Mar 6, 2016 | 05:20 AM
Originally Posted by dr.fixit
........ I tried asking the parts guy at the local Jag dealer, but he wouldn't tell me. .....
If he had looked it up for you on JEPC, this is what you'd have seen:
P/N LJA2610AA with a frequency of 315mhz.
Europe uses 433mhz which is no good for US spec vehicles.
If you source a used fob on ebay etc, you can programme it yourself without any tools. Keys must be programmed using dealer level Jaguar SDD.
Old Mar 6, 2016 | 07:49 AM
reb1999's Avatar
Tis why I use me key as often as I can. Saves the remote when I really need it.
Old Mar 6, 2016 | 12:55 PM
stevepaa's Avatar
see this
https://www.jaguarforums.com/forum/x...ictures-93167/
Old Mar 6, 2016 | 02:32 PM
Ungn's Avatar
I'm not sure that works with an "early" XK8.
I would love it if it did.
Old Mar 6, 2016 | 05:13 PM
motorcarman's Avatar
There are (2) 315mhz XK/XJ keyfob transmitters for North America. The VIN split is around 2000/2001 MY cars.
The EARLY one is pictured on the LEFT and the later one is pictured on the RIGHT.
bob
Old Mar 6, 2016 | 07:40 PM
Ungn's Avatar
bob
The left is the LJA2610-AA, The right is a LJE2610-AB or LJE2610-AC.
The AC's are all over E-bay for $30 and are compatible with the Key in FOB mod. The AA's are usually twice this.
Old Mar 8, 2016 | 06:56 AM
lilfreddie's Avatar
I just wanted to let everyone know that the inexpensive Ford Keyfobs work on our cars. I typed the fcc number on eBay was looking for a replacement and the Ford set came up super cheap so I tried them and they work.
Old Mar 8, 2016 | 07:21 AM
JonWat's Avatar
I bought one of these off ebay to replace the rubber buttons in my fob which were starting to look worn.
Only 4 quid & a perfect fit.
Old Mar 8, 2016 | 07:59 AM
scardini1's Avatar
You're kidding me! The buttons are exactly the same size? Mine are pretty tatty. That would be great! Simply brilliant.
Old Mar 9, 2016 | 07:10 AM
lilfreddie's Avatar
Default Sorry these did not work on my daughters 99 XK8
I jumped the gun I tried to program these to her car yesterday day and they won't work totally different FCC number. Back to the drawing board.
Old Mar 10, 2016 | 08:05 AM
Do they work for your 2001 XJ8????????????????
bob
Wenlock
Mar 5, 2016 02:59 PM
2572
XF (X260)
Mar 5, 2016 08:00 AM
Harry Dredge
Mar 3, 2016 01:21 AM
64vette
Non-Jaguar Vehicles
Feb 29, 2016 08:03 PM
jacktoth
Feb 29, 2016 04:49 AM
