horror pictures
Old Oct 3, 2016 | 04:32 PM
phanc60844's Avatar
Default horror pictures
Warning, these are not for the faint hearted. If you thought only the secondary tensioners were an issue you will opt for the full change after seeing these:
If your VVT solenoids are mounted on the timing cover, then its a simple matter of poping off the 30mm (or so) diameter blanking cap on the cam covers and boroscope the chains and guides. I only started out trying sort out an oil leak but i thought while I was in there I'd take a look. Looks like a piece has already dropped off and whats left is only just hanging on.
File Type: docx
File Type: docx
File Type: docx
File Type: docx
Old Oct 3, 2016 | 07:35 PM
Jag#4's Avatar
Can't open the pictures.
Old Oct 3, 2016 | 07:40 PM
Dale Dunn's Avatar
+1 on not being able to view pics
Old Oct 3, 2016 | 07:41 PM
Jandreu's Avatar
Me neither, likely due to the file format. Try reposting them as either JPEG or PDF
Old Oct 3, 2016 | 07:55 PM
Stratohammer's Avatar
They'll open fine in Open Office
Old Oct 4, 2016 | 12:41 AM
phanc60844's Avatar
They were screen dumps from a bespoke movie format, so I just pasted them onto a word document, they should open in word
Old Oct 4, 2016 | 07:00 AM
phanc60844's Avatar
After some messing about (in works time i might add)
Attached Thumbnails horror pictures-guide1.jpg   horror pictures-guide2.jpg   horror pictures-guide3.jpg   horror pictures-guide4.jpg
Old Oct 4, 2016 | 07:45 AM
RaceDiagnostics's Avatar
Remind us what year and model you have.
Old Oct 4, 2016 | 07:58 AM
phanc60844's Avatar
Its a 1998 XK8 coupe
Old Oct 4, 2016 | 08:50 AM
grantorino62's Avatar
Please put that info in your signature!
Old Oct 4, 2016 | 08:57 AM
phanc60844's Avatar
you try and do someone a favor and all they do is moan about your signature!
Old Oct 6, 2016 | 06:44 PM
I'm not moaning! I refuse to scroll up 8 or 10 posts to refresh my memory of what car you own and its year. Its such a simple thing, unless you try to do it on a phone rather than a lap top! 108 posts and I'm the first to request this?
Old Oct 8, 2016 | 02:49 PM
phanc60844's Avatar
yes you are the first, the one, the only!
Old Oct 9, 2016 | 05:35 AM
So whats your plan.
Old Oct 9, 2016 | 10:20 AM
phanc60844's Avatar
Originally Posted by RaceDiagnostics
So whats your plan.
Plan?
It's currently minus a radiator and front bumper. While I wait for the timing chain kit to turn up I'm taking the opportunity to decrease ,derust and Dinitrol spray the front end. in the process I've partially stripped the bottom gearbox oil cooler union and broken the bottom threaded boss on one of the headlights. The radiator fix is a M18 male to female adapter off eBay, hoping to screw it on with what threads are left and some locktite hydraulic seal should stop it leaking. Not decided what to do with the light yet
Old Oct 9, 2016 | 10:30 AM
The bottom light fixing is not needed, both mine were gone before I purchased the car.
Old Oct 9, 2016 | 10:57 AM
phanc60844's Avatar
Thanks for that ,I'll just glue the bits back then. I was going to get a metal bush made, weld it to a plate then epoxy it back but I won't bother. With the adjustable bush, i thought it was something to do with alligning the beams so was a critical part?
Old Oct 15, 2016 | 09:09 AM
phanc60844's Avatar
Got the chains on now, just need everything tightening. I had an issue with the locking peg for the flywheel. It just wouldn't go in, not convinced that it is the correct size but after tapering it slightly it has just started but not in fully. The timing mark was half a segment retarded as well! not sure what that equates to in degrees but I had an issue prior that the car wasn't that responsive in low revs, hopefully I've just found the reason? The A bank primary chain was slack on disassembly, looks like the tensioner was stuck, it was about 3mm less extended than the B bank and I had a small amount of chain slap on overrun. Its good to find the reasons for issues
Attached Thumbnails horror pictures-20161011_184656.jpg   horror pictures-20161015_131122.jpg
XK_SL
Jan 31, 2024 07:55 PM
BradsCat
Sep 13, 2016 06:47 PM
2e0wdj
Sep 12, 2016 09:54 AM
Atlastajag1
Sep 8, 2016 09:23 AM
Tigro
Sep 7, 2016 09:55 AM
