Mystery Object. What is this?
Old Sep 26, 2016 | 02:42 AM
frankc's Avatar
Default Mystery Object. What is this?
I moved the XKR off the drive this morning and found this on the floor. Any idea what it is and where it belongs?
Thanks.
Old Sep 26, 2016 | 07:58 AM
kreyszig's Avatar
Can't say I remember seeing any brass parts on my xkr. I think you've picked that up as you've been driving somehow.
Old Sep 26, 2016 | 08:15 AM
ccfulton's Avatar
Agree, I've never run across anything made of brass, never mind shaped like that and with an o-ring.
Part of a lawn sprinkler perhaps or some other water transport apparatus?
Old Sep 26, 2016 | 08:48 AM
03 XKR's Avatar
+1 on the sprinkler, is the post with the o-ring hollow? There also appears to be a slash along the cap indicative a 45 degree sprinkler head, pop up type. The o-ring has worn and allowed the assembly to be ejected from the body of the sprinkler and/or missing ring clamp as well, maybe still inside the sprinkler body. The top 'peg' may have secured to a larger diameter cover which further conceals the pop-up sprinkler.
Old Sep 26, 2016 | 09:57 AM
Rick L's Avatar
It's a Sparepiece. Jag puts them in all engine compartments. That way when you find it you take your car to the dealer and they can charge you $1000.00 to "put it back
Old Sep 27, 2016 | 12:54 PM
frankc's Avatar
Good guesses guys, problem is I have never seen a pop up sprinkler in the UK. We depend on the actual rain to do the watering over here.
After much research and helpful hints from others I have decided its part of a pressure washer valve.
Old Sep 28, 2016 | 02:17 AM
StuG's Avatar
It's an integral part of the flux capacitor. It needs to be properly inserted back in place if you intend on achieving time travel upon reaching 88mph.
Old Sep 28, 2016 | 02:12 PM
pbuck's Avatar
Do you home-brew beer? It looks like a part for that.
A relief valve, perhaps?
Old Sep 28, 2016 | 02:40 PM
brgjag's Avatar
That is a seldom seen o-ring maker. When take that o-ring off, then dip it in water then another o-ring appears. Good for 29 O-rings, after that hollow it out and you have a ring like the one you have on.
Old Sep 28, 2016 | 03:02 PM
oddjob2000's Avatar
OMG, that's your left hand. How did you not notice that dropping off??
Old Oct 2, 2016 | 04:55 PM
wolfpck1's Avatar
possibly a pressure washer tip?
Old Oct 2, 2016 | 05:40 PM
That's something to be thankful for Frank.
georgios
Feb 16, 2017 11:20 AM
mrplow58
Oct 17, 2016 05:55 PM
0353
Oct 2, 2016 11:42 AM
Ducmon
Sep 24, 2016 10:17 AM
ghrim6262
US Midwest
Sep 21, 2016 08:08 PM
