mystery threaded hole at rear end of SC snout
Old Nov 29, 2018 | 08:30 PM
zray's Avatar
Default mystery threaded hole at rear end of SC snout
mystery threaded hole at rear end of SC snout ? Anything supposed to be threaded into this hole ? It's about one inch deep.
Old Nov 29, 2018 | 08:54 PM
mhminnich's Avatar
Nothing in mine either.
Old Nov 30, 2018 | 03:43 AM
frankc's Avatar
Watch that black pipe. The are VERY brittle.
Old Nov 30, 2018 | 08:38 AM
zray's Avatar
affirmative.. I only put enough tension on it to move it an inch. I siliconed all the hose in an effort to slow down oxidation.
It may be over-kill, but after the car has had a good workout, and is parked in the garage, I then raise the hood to keep the engine heat from cooking the myriad of hoses any more than absolutely necessary.
Z.
Old Nov 30, 2018 | 09:11 AM
jackra_1's Avatar
Originally Posted by zray
affirmative.. I only put enough tension on it to move it an inch. I siliconed all he hose in an effort to slow down oxidation.
Z.
I do the same as you for the same reason.
Also to deter mice from making nests in the Winter here when the Jag is not used frequently.
Old Dec 1, 2018 | 04:17 AM
frankc's Avatar
I am the same. Its a bit cold and soggy in the UK at the moment but I always ensure I give the car a..... 'vigorous' drive once a week to shake off any cobwebs.
If anyone does ever break those black pipes let me know I have a fairly simple fix, tried replacing none available.
Old Dec 1, 2018 | 11:26 AM
giandanielxk8's Avatar
None of mine are broken, yet, but I would like to know the simple fix. For future reference of course.
Old Dec 2, 2018 | 03:46 AM
frankc's Avatar
Here you go, I did say it was a simple fix.
First the problem https://www.jaguarforum.com/showthre...l=1#post941561
Then the solution https://www.jaguarforum.com/showthread.php?t=75123&p=941769&viewfull=1#post941 769
Old Dec 2, 2018 | 08:01 AM
jackra_1's Avatar
Good job.
Those Norma Connectors seem to be impossible to source unfortunately and I have tried.
Everyone uses them but no standard sizes.
Old Dec 3, 2018 | 03:59 AM
frankc's Avatar
Originally Posted by jackra_1
Good job.
Your right about that. I found a similar pipe but no Norma connectors. I purchased two other pipes with Norma connectors on. The idea being I take the connectors off those and fit it to the pipe I bought. Basically a lot of wasted money and the 'fix' I did looks and works well. I do not like bodging things but my fix was better than leaving it as it was.
Old Dec 3, 2018 | 04:35 AM
Robman25's Avatar
Just google Norma connectors and you will see the suppliers.
Old Dec 3, 2018 | 04:59 AM
jackra_1's Avatar
I went thru the same process trying to get the correct norma connectors with the same thought process as you. Looked at Ford and Lincoln and others no luck.
Old Dec 3, 2018 | 05:00 AM
jackra_1's Avatar
Did that no luck.
Old Dec 4, 2018 | 03:52 AM
frankc's Avatar
Cool
Ohhh never thought of that. Perhaps you could help us and do this google thing and show us where we can purchase a single Norma connector for that pipe.
Old Dec 4, 2018 | 05:24 AM
Robman25's Avatar
Not too sure if I should be reading this as a sarcastic reply or not but I have requested from the manufacturers whether Norma connectors can be purchased singly.
Old Dec 4, 2018 | 07:28 AM
jackra_1's Avatar
I doubt whether Norma will sell one or two connectors however if members wanted to do a "group buy" that could be a different story.
There are two types on my XJR :
NORMAQUICK® V2
NORMAQUICK® V2 plastic quick connectors are an ideal means to connect media carrying lines as well as ventilation and exhaust lines in the automotive industry. Used for both line-to-line and line-to-device connections.
  • Material: Injection Molded Thermoplastics, EPDM O-Rings
  • 0˚, and 90˚ standard profiles/ over 200 custom profiles
  • Inside Spigot Diameters: 4mm – 33mm
SERIES C-STYLE (0˚PROFILE)
Craig Assembly C-Style “push and seal” plastic quick connectors are ideal for joining lines used to transport media in cooling water, glycol, and water applications. They also are excellent in charged-air systems. Designed for the VDA standard spigot. Feature a positive retainer ring mechanism for tight locking seal and available with hose barb stem for use with aftermarket hose and clamps.
  • 0˚profile (Straight)
  • Inside Diameters: (12mm – 50mm)
iramphal
Oct 24, 2017 07:38 AM
MK2
Sep 24, 2017 02:39 AM
Some Day, Some Day
Mar 30, 2017 06:12 PM
GWD
May 21, 2014 04:24 AM
Karmak
Mar 12, 2010 11:40 AM
