Nikisil Liners--Care of
Old Nov 7, 2011 | 08:12 AM
geminicptron's Avatar
Default Nikisil Liners--Care of
I have a 1997 with Nikisil liners and 30K miles. No problems so far. What special care should I give this engine to prevent problems in the future.
Old Nov 7, 2011 | 08:25 AM
The Coupe's Avatar
The general consensus seems to be that if you've got a Nikasil-lined engine that's in good shape now, then you've got a superior engine that is preferable to a traditional steel cylinder engine.
The original problem had to do with high levels of sulfur in gasoline, which has now been outlawed for nearly a decade, I believe. Most believe that the Nikasil engines with real problems are now dead. So if yours is healthy, then enjoy and don't worry about it. You'll have plenty of other little projects to address on your car.
Old Nov 7, 2011 | 09:14 AM
80sRule's Avatar
+1.
Just make sure not to make short little trips and use decent gas and it should give you an excellent service life.
Old Nov 7, 2011 | 09:27 AM
RCSign's Avatar
I agree with "The Coupe" You don't have to worry, one thing I do is buy the same fuel and I'm a stickler about it. Shell 93 Octane. I have a friend who worked for BP and he told me that the formulas for fuel was consistent among the national brands. He was the foreman at a distribution center. All gas regular, premium, etc come in on the same pipeline. The additives are added as the tankers are being filled. The national brands have set formulas, where as your local convenience store's manager will tell the distributor what to add. So you really may not be getting the best blend. Just throwing my 2 Cents worth in.
Old Nov 7, 2011 | 03:21 PM
Thanks everyone for the good news. I will sleep much better.
What grade of oil should I use and how frequently should I change the oil considering Nikisil liners. What do the Gurus say?
I have changed the tensioners, the stat housing and the water pump. So I should be in the clear.
Old Nov 7, 2011 | 07:41 PM
RCSign's Avatar
Gemi
I change my oil every year, but I only put about 4000 miles a year on my car. Sounds like your good to go.
Old Nov 7, 2011 | 08:30 PM
motorcarman's Avatar
DO NOT OVERHEAT THE ENGINE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!
bob gauff
Old Nov 8, 2011 | 01:06 AM
xenophobe's Avatar
Do not travel to the past to buy gas. As long as you can avoid time travelling to avoid harsh gas, you have nothing to worry about.
Actually, if your Nikasil liners are good, you're better off with them.
doclees
Apr 12, 2015 10:49 PM
Angrycanuck
May 20, 2014 08:42 PM
quartzeye
Apr 16, 2014 06:52 PM
Spurlee
Feb 18, 2013 10:02 AM
brucelee
Nov 9, 2012 10:16 PM
