No crank
Old May 22, 2022 | 02:45 PM
giandanielxk8's Avatar
Default No crank
Car was running well this morning. I went to the hospital and now that I’m leaving the car won’t crank.
I’ve got no codes. The fuel pump is working as I can hear it. Dashboard lights all light up as they should. But, when I turn the key, nothing happens. Not even an attempt at cranking.
I do have booster cables with me, but no other car nearby to attempt to jump the car. Also, I’m quite far from any chain parts store where I could have the battery tested.
I checked the immobilizer but that did nothing. Any ideas before I have to call a tow truck?
Old May 22, 2022 | 03:01 PM
A passerby was generous enough to help me jump-start the car. This is either battery or alternator related.
Old May 22, 2022 | 03:46 PM
RJ237's Avatar
Or cable/ground connection.
Old May 22, 2022 | 08:34 PM
I had not thought of that. I’m going to have the battery load tested tomorrow and will check the cables and ground.
Old May 23, 2022 | 04:02 AM
DavidYau's Avatar
GD,
Always nice to have a stranger help out. Shows that there are nice people around.
One of the first jobs I did was put in new upgraded solid copper battery cables. When I first got the car I noticed that the old cables heated up which is never a good sign. If your battery tests fine, it's probably the cables. A decent garage would also check the alternator at the same time. If you're replacing, do both +ve and ground - order the right lengths without crimps.
Also later I put in a new engine ground cable (which was a bugger as it's under a hard to reach bolt for the CAT converter).
Old May 23, 2022 | 04:09 PM
The battery tested badly. It couldn’t hold its charge. I bought a new AGM battery. Hopefully that’s the end of this problem. The old battery was about 4 years old.
Old May 23, 2022 | 08:33 PM
bcprice36's Avatar
There you go! Us old Folks don't put out much spark anymore!
Good Luck with the new Battery.............
Billy Clyde @ Cinco RAnch
Old May 23, 2022 | 09:06 PM
DavidYau's Avatar
Default Speak for yourself
GD- The old dead battery problem. At least you weren’t stranded.
BCP,
Bit of advice to all old folk - The blue pills work! Hehe!
Cory Klock
Nov 12, 2020 10:26 AM
XJRonehundred
Jan 26, 2018 02:10 PM
blackwolf560
Apr 30, 2016 02:58 AM
X-TypeMentality
Feb 5, 2014 05:56 PM
jignesh111
Mar 24, 2011 01:08 PM
