NORMA Tube Connector?
Old Oct 9, 2023 | 05:21 PM
Chip Abbadessa's Avatar
Default NORMA Tube Connector?
My '99 XK8 developed a leak at the juncture between the coolant tube emanating from under the intake manifold to the NORMA fitting on the Octopus Hose. Please see the photo. Does anyone have experience with this? Part number or work-around?
Many thanks for the collective insight.
Old Oct 9, 2023 | 05:35 PM
Default Looks like #8
Old Oct 9, 2023 | 06:08 PM
giandanielxk8's Avatar
Remove the norma, and attach the hose directly to the metal pipe with a hose clamp. If it's a T, which I think it is, add in a 5/8th (I think, not sure), bronze barbed T, and attach both hoses to it, then another section of hose to the pipe, and you're going to need a few clamps. Problem solved, and will last longer than the Norma.
Old Oct 9, 2023 | 06:33 PM
motorcarman's Avatar
I keep 3 or 4 THREE WAY CONNECTORS in stock for all my X100/X308 cars.
The resin breaks down after several years and they need replacement.
Old Oct 9, 2023 | 08:42 PM
This is exactly what I was looking for, thanks!
Old Oct 10, 2023 | 04:35 AM
Yeah, before you go ahead with that, is this the three way connector under the intake or the one under the coolant expansion tank? You should measure the hose diameters before you commit. I am not sure about the ⅝.
Also you can do a search on the forum. This is a fix that has been documented before.
Old Oct 10, 2023 | 09:29 AM
The actual part from Jaguar or aftermarket sellers is about $5.00 US.
Old Oct 10, 2023 | 12:16 PM
xalty's Avatar
twist until you get the to the raised part and then pull it off
there’s an o-ring in there lube it up good
Old Oct 10, 2023 | 08:45 PM
Thanks!
Ophitoxaemia
Oct 11, 2024 06:38 AM
mat32essex
Apr 24, 2019 09:30 AM
jag4dummies
Apr 7, 2019 04:00 AM
srmpf
Jan 19, 2014 01:48 PM
srpope80
Jan 26, 2012 04:02 PM
