oil in air intake duct
Old Mar 3, 2013 | 01:17 PM
2000CAXK8's Avatar
Default oil in air intake duct
I happened to take of my air intake and figured I would wipe it down since it seemed to be oily when I noticed the inside of it was covered in oil...
Is this normal?
The following pic what dripped out after I had already scrubbed the inside with a dish brush and soap.
Old Mar 3, 2013 | 02:40 PM
2000CAXK8's Avatar
and to make matters worse I broke this breather hose by closing the hood while it was at an angle...
JA-NCA3951CB - Breather Hose Full Load, XK8 Air Intake
Old Mar 3, 2013 | 03:41 PM
smoggyx100's Avatar
Hi
Yes the oil needs cleaning out yearly. There is a link in the DIY threat at the top of the thread list that gives a link to detailed instructions on this including cleaning the MAF and breather hoses. DiY_Document_Clean_MAFS.pdf
Old Mar 3, 2013 | 03:44 PM
chopr's Avatar
If I had a nickel for every one of those broken breather hoses...! All part of the Jaguar experience!
Old Mar 3, 2013 | 04:11 PM
2000CAXK8's Avatar
Originally Posted by smoggyx100
Hi
Thanks for the link, coincidentally I had gotten a po455 code last month. After tearing down the drivers front wheel well to inspect the emissions recovery valve I found that simple little "Part-Load Breather Tube" on the left cam cover had become disconnected on its own.
Old Mar 3, 2013 | 04:59 PM
Paul Pavlik's Avatar
The disconnected Part Load Breather would cause some oil in the Intake Duct.
Old Mar 4, 2013 | 02:23 AM
XKRacer's Avatar
Check the wire mesh/wool has not come adrift in the cam cover, very common, you can see it by shining a torch down the hole where the breather goes.
Alternatively get yourself a aluminium intake pipe and pipe the breather down the front of the engine, at least you will never get oil in your intake again
Old Mar 4, 2013 | 07:24 AM
The Coupe's Avatar
As Tony says, check to make sure your oil separator is in place in your right-hand valve cover. Details here:
Oil in your airbox - might be an easier fix than you think FAQ
Old Mar 4, 2013 | 10:54 AM
2000CAXK8's Avatar
When I had the cam cover off (6 months ago) the screen assembly was still there. When I look into the hole now I see a flat piece of aluminum, not the cams. So I believe the mesh and shield is still in place.
Just ordered a new filter and breather hose from xks unlimited this morning. It will be here tomorrow.
Kevin Burnaby
Jun 28, 2020 08:04 AM
cissdm
May 3, 2016 06:02 AM
Scarecrow
Mar 28, 2016 03:17 AM
teacoff
Sep 10, 2015 08:25 AM
1100me
Sep 7, 2015 06:26 AM
