Radio - no sound
Old Jan 5, 2023 | 09:48 PM
Gladiator26's Avatar
Default Radio - no sound
Radio turns on but no sound is coming out, same outcome if you play a CD. Fuses all tested OK. Any thoughts?
Old Jan 6, 2023 | 03:49 AM
Robin Smith's Avatar
Did it just stop working? Premium or standard system? If premium, there is an amp in the boot/trunk above the CD player. Any work gone on that area lately? Suggest you check all connections in that area.
Old Jan 6, 2023 | 09:20 AM
Thank you for your reply. It worked the first few month. The antenna was slightly bent so I kept it in the up position and disconnected the motor. I don’t remember seeing an amp but will check again today.
Old Jan 6, 2023 | 12:43 PM
Johnken's Avatar
Fyi amp is on shelf above cd changer.
Do you have "tweeters" in the door's sail? I could be wrong but I think that IDs premium.
"Sail" = the sail shaped triangular area from the of front windows, inches from outside mirrors.
If still no go, please say:
if cd holder loads / unloads properly.
If radio lights up.
John
Old Jan 6, 2023 | 12:56 PM
I do have an Amp above the cd player. Cd player works and shows track playing. Radio works and shows am fm stations. Just no sound.
I noticed a little water condensation near the AMP so I am taking apart the amp to clean around it.
Old Jan 6, 2023 | 04:32 PM
zray's Avatar
I had the same symptoms, but no easy way to test the amp.
Ebay had numerous amps for sale with the correct part number, starting at about $35.
For that price I felt I had little to lose and bought the cheapest one on eBay for under $40 including shipping. Luck was with me and the used amp fixed my no-music blues.
worth a try.
Z
Old Jan 6, 2023 | 06:15 PM
After removing the amp and cleaning around it, I plugged everythin back in, also worth mentioning that I reinsreted the power antenna fuse. The sound is back on surprisingly. I am grateful for everyone's replies. This forum rocks.
Old Jan 6, 2023 | 07:18 PM
zray's Avatar
I’ve had my power antenna fuse pulled for
so long I forgot the antenna is there. Just no need for FM / AM until the apocalypse. And the rest of the sound system is independent from it.
Z
PS perhaps I should mention that the amp worked intermittently for about a year before it died altogether.
conor
Nov 14, 2017 11:56 AM
flibberflops
Dec 20, 2015 10:01 AM
03jagstype
Dec 5, 2015 10:58 PM
Angel279
Apr 10, 2014 01:34 PM
TommieBoy
Aug 17, 2008 05:52 PM
