Radio went dead after battery disconnect
Old Jun 20, 2015 | 06:04 PM
Jetjock17's Avatar
Unhappy Radio went dead after battery disconnect
Disconnected the battery of my 2004 XK8 to work on passenger seat module. On reconnecting the battery, my radio is dead! Worked great before so I checked fuses and all seem to be OK. Help please!
Old Jun 20, 2015 | 06:07 PM
MediaBobNY's Avatar
Try inputting the PIN code, even tho it's apparently not asking for one.
Old Jun 20, 2015 | 06:11 PM
cjd777's Avatar
Jetjock, Look in your paper work for a radio code. A four digit number, If you have all the paper work with the car it will be on a card, I have found them written up in the corner of a page that shows how the radio works. A Jag dealer can give you the number if you go there and show proof of ownership and the VIN number.
Wayne
Old Jun 20, 2015 | 06:22 PM
Jetjock17's Avatar
Thumbs down No radio code!
Thnx for the suggestions but unfortunately did not receive original paperwork fromthis US car when imported to Canada. Radio seems dead so not sure if entering a code would work. Looks like I should try the battery reflash procedure where the ground wire is connected to the positive terminal for 10 secs than reconnected. Sort of like a reboot!
Old Jun 20, 2015 | 06:33 PM
MediaBobNY's Avatar
That's a hard reset. A reflash would involve reinstalling the software.
Old Jun 20, 2015 | 06:40 PM
Jetjock17's Avatar
Wink Hard reset worth a try
Again many thnx for help. Will try a hard reset and hope!
Old Jun 21, 2015 | 03:26 AM
cyber3d's Avatar
Well, . . . there are only 10,000 combinations in a 4 digit code.
Just kidding. Hope you get it fixed.
Old Jun 21, 2015 | 05:16 AM
Jetjock17's Avatar
Cool No luck with Hard Reset
Well looks like this radio wants a code. Will try the local dealer nest week and see if he can help. The car was in for service recently and itlooks like the battery terminals were cleaned and coated so someone must have reset the radio code. The search begins!
Old Jun 21, 2015 | 07:36 AM
Do you mean DEAD as in no signs of life or is it powering up and displaying the word CODE?
Coded radios are very rare but not unknown in US market models.
Old Jun 21, 2015 | 09:33 AM
Jetjock17's Avatar
Unhappy Dead as a doornail!
No signs of life. No audio and the display is blank. Checked all the fuses in the fascia, trunk and under the hood and they are all good.
Old Jun 21, 2015 | 09:43 AM
WhiteXKR's Avatar
Then a code is not not the issue. The display will say 'code' if you need to enter one.
It is easy to miss a hairline break in a fuse, especially if you are looking at all of them. I suggest replacing fuse F9 (10 Amps) and F12 (5 Amps) on the passenger side of the dashboard, or at least checking them with a multimeter.
Old Jun 21, 2015 | 10:10 AM
Jetjock17's Avatar
Thanks for the tip. I have checked all with an Ohmeter and they all passed but I'll try relacing the two you suggested. It sure looks like a fuse to me too. I guess there isn't an inline fuse for the radio?
Old Jun 21, 2015 | 10:33 AM
WhiteXKR's Avatar
There would be only if your car has an aftermarket radio installed.
Old Jun 21, 2015 | 11:01 AM
Jetjock17's Avatar
Well, I replaced the F9 and F12 fuses in the passenger facia panel and no change.
Old Jun 21, 2015 | 11:32 AM
WhiteXKR's Avatar
If you gave a DMM, set it to volts and see if you have about 12 volts at the exposed metal on the top of each side of both those fuses, with the ignition on.
Old Jun 21, 2015 | 02:04 PM
Jetjock17's Avatar
Success sir! Not really sure what happened but when checked F12, it showed no voltage. Re-installed and bang the radio lit up! Will clean all the connectors with contact cleaner but dirty contacts looks like the problem. Thank you very much for your help and patience.
philwarner
Oct 4, 2024 01:37 PM
Malihide
Apr 2, 2016 04:05 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
daniel06
XE ( X760 )
Sep 15, 2015 07:07 AM
DuhCar
Sep 11, 2015 10:58 AM
