Rear bumper problem
Old Jul 24, 2019 | 04:28 AM
jelu02's Avatar
Default Rear bumper problem
Hi,
I have a problem with my XK8 2004 rear bumper.
The left beam mounting bracket https://www.sngbarratt.com/uk/#!/Eng...6-0d29da17980a had totally disintegrated.
Where the aluminum adjustable piece was, there remained only some small pieces and some white dust.
The right bolt going through the mounting bracket came out alright, but the left one I cannot get out.
The nut inside the beam is lose and just spinning.
I must take the bumper apart to get to the nut.
I found this instruction on the the forum:
https://www.jaguarforums.com/forum/x...stment-101947/
My question is:
Where can I get the nine new fasteners and center pins that hold the bumper cover to the beam?
Jens Lumbye
Old Jul 24, 2019 | 04:36 AM
laguillotine's Avatar
Just to clarify, do you really have to take the bumper off?? i.e is it hanging off?
I had a similar issue where one of the bracket to bumper bolt came out and the other just spins. I could not remove the bracket to car bolts as the heads are too rusty. So rather then cut off the bracket and replace it, then take the bumper apart and etc.. all which was looking to cost more and more I have just left it.
Old Jul 24, 2019 | 04:45 AM
jelu02's Avatar
Yes, I have to take the bumper off.
It is now only secured by the right mount, where I succeeded in geting the bolt out and replacing the mount with a new one.
The only way to get to the spinning nut is to disassemble te bumper.
Old Jul 24, 2019 | 05:05 AM
As you are in Sweden, I think you will have the non-energy absorbing bumper with the plastic beam? The energy absorbing version used in the US has a metal beam.
It sounds like you have got beyond this stage .......
........... and progressed to fitting the replacement brackets:
The steel hexagon bolts (see item 5) which go through the brackets screw into brass "nuts" in the plastic beam. These frequently seize and just rotate when you try to remove the hexagon bolt. You can be brutal removing the hexagon bolts by cutting off the heads. The brass "nuts then usually fall out of the beam (see item 1) and can be separated on the work bench.
New hexagon bolts (P/N JBU11218E) are available from Jaguar:
https://www.jaguarclassicparts.com/uk/part/JBU11218E
Rarely for Jaguar parts, these are very low cost!
Old Jul 24, 2019 | 06:32 AM
jelu02's Avatar
OK
Seems like a good solution.
But how do I fixate the brass nut in the beam so it doesn't rotate when tightening the new bolt?
Old Jul 25, 2019 | 08:26 AM
SuperGlue. The bond will be stronger than the plastic bumper beam.
On re-assembly, coat the threads and shaft of the hexagon bolts with Copaslip to prevent the steel seizing to the alloy:
Old Jul 25, 2019 | 08:31 AM
jelu02's Avatar
Thanks Graham!
I will follow your advice.
Old Jul 25, 2019 | 11:33 AM
DavidYau's Avatar
Default Copper lube is one of the greatest garage secrets
For those of us who keep cars a long time, copper anti seize lube must be one of the best garage secrets.
Still don’t know how exactly it stops contact corrosion, including steel and aluminium contact (bi metallic corrosion), but it works for years.... always.
Old Jul 26, 2019 | 02:27 AM
jelu02's Avatar
No, that is strange. Copper is a very good electrical conductor, and still copper-paste does prevent bi metallic corrosion. I heard of one who used copper-paste in the contacts for his central electronic unit. That didn't turn out very good :-o
Old Jul 26, 2019 | 03:13 AM
I prefer the aluminium based equivalent. Land Rover supply the Zeta brand (high pressure + high temperature + anti seize) but there's plenty of others available.
Used on the face of hubs where they contact the wheels, it doesn't show against the alloy the way Copaslip does.
hunterpedigo
Jun 21, 2017 08:59 PM
hunterpedigo
Oct 29, 2015 05:31 PM
BigBossRadio
Mar 16, 2014 10:35 AM
r0m8470
Jun 11, 2012 11:38 AM
Innovative Detailing
Detailing / Car care
Jan 24, 2012 12:31 AM
