rear dif seal question
Old Nov 14, 2024 | 11:30 AM
wymjym's Avatar
Default rear dif seal question
My rear dif has been leaking, is this seal correct for the front (pinion) output?
Motive Gear Performance Differential 5778 Motive Gear-Differential Pinion Seal Differential Pinion Seal Motive Gear Performance Differential 5778 Motive Gear-Differential Pinion Seal Differential Pinion Seal
I've seen pricing all over the place and need some advice.
thanks
wj
Old Nov 14, 2024 | 12:59 PM
motorcarman's Avatar
INFO for you.
File Type: pdf
File Type: pdf
Old Nov 14, 2024 | 01:17 PM
kstevusa's Avatar
Bob has the preferred info and Jag procedure above. The dif housing is a Salisbury part and made at the Salisbury Plant owned by Dana Corp. The housing and pinion may be similar the the Dana 44, and if so, the seal should fit. The Jag housing will accept Dana 44 gears if a mod is made to the dia. of the ring gear bolt holes and modified bolts are used. There is limited amount of info on the kinship for Jag Salisbury and Dana 44, but it can be found if searched thoroughly... None of above is confirmed by personal tests so I only relay what research has shown. Google- Jag Salisbury and Dana 44 differential.
Old Nov 18, 2024 | 11:22 AM
wymjym's Avatar
thanks for the input and different approach considerations.
As to the seal...since it is @ $9.00 usd I'm going to order it and do a side by side comparison with the one I remove.
Is there another 'seal' (O ring) that fits behind this seal?
wj
Old Nov 18, 2024 | 02:29 PM
RichardS's Avatar
If I remember correctly it's just a conventional lip seal which runs along the outer surface of the flange which you pull out once you have removed the nut. Make sure that you check the removal and torque procedure for the nut before you remove it.
Richard
Old Nov 18, 2024 | 05:41 PM
For simplicity, you can mark the nut and reuse. Put it back EXACTLY where it was with a little threadlocker to get the preload the way it was from the factory.
Just a suggestion.
Old Nov 19, 2024 | 08:06 AM
wymjym's Avatar
Just a suggestion.
Your suggestions are always appreciated
WJ
Old Nov 19, 2024 | 09:03 AM
Don B's Avatar
Hi wymjym,
Just a heads up that when the diff pinion seal leaks, it can be an indication that the pinion bearings are worn. Check your pinion shaft for any discernible play and check the backlash between the pinion gear and the diff crown wheel/ring gear. I think the acceptable backlash is listed in the Workshop Manual, which you can download from the DIY Quick Links thread.
If the pinion bearings are worn, your new seal will not last long.
Cheers,
Don
Old Nov 19, 2024 | 05:12 PM
wymjym's Avatar
Will do, thanks
Looks like I have some fun times ahead.
WJ
Old Nov 22, 2024 | 12:19 PM
sossybaby's Avatar
My understanding is Jaguar stopped selling the seal and you had to buy the whole flange assembly with Ryton ring for $300+, so for 9 bucks it's worth a try.
In the UK the cheapest i could find was £65. JLM20326.
lhjones
Dec 17, 2023 05:33 PM
etaent
XJ40 ( XJ81 )
Nov 25, 2023 03:06 PM
Darrenmb
Mar 19, 2022 07:49 PM
John Baker
Jun 3, 2020 05:00 PM
JensenHealey
XJ40 ( XJ81 )
Feb 8, 2020 01:00 PM
