Remote programming and read distances
Old Apr 12, 2026 | 11:44 AM
Pantera928's Avatar
Default Remote programming and read distances
There is a procedure to program a remote involving flashing the headlamps etcetera and it works fine. I have an issue with two remotes and if one is programmed and working, It stops working if you program the second one. You can always get one to work but never both at the same time. Tried having the programmed om far away when programming the other but that did not work.
Am I missing something?
Also, both remotes need to be next to the car to work. If you are more than a couple of feet away, they don't. Both have new batteries.
Ideas?
Old Apr 12, 2026 | 12:36 PM
Stumpy's Avatar
You are aware that you need to program all remote FOBS at the same time ? 5 lock or unlock button presses to complete the procedure ? If you only have two remotes that is 3 presses on one remote + 2 presses on the other
Old Apr 12, 2026 | 01:44 PM
Pantera928's Avatar
@Stumpy I have never heard that before. I will give it a try
Old Apr 12, 2026 | 01:58 PM
Stumpy's Avatar
Here is the information about programming the remote FOBS.
I did not get the beeps described in the instructions.
Old Apr 12, 2026 | 04:55 PM
Pantera928's Avatar
@Stumpy I tried the way you mentioned and now both remotes work but still only 2 feet away from the car.
Could the receiver in the car be causing something like this?
Old Apr 12, 2026 | 06:28 PM
motorcarman's Avatar
The receiver antenna is in different location for the coupe vs the convertible.
The coax connection at the SLCM can also be loose/faulty
Old Apr 12, 2026 | 07:34 PM
Pantera928's Avatar
@motorcarman
This is a convertible. Can you tell me where it is located?
Old Apr 12, 2026 | 08:28 PM
Under the right interior 'CAP' aft of the 'B' pillar and forward of the subwoofer enclosure.
Old Apr 13, 2026 | 04:39 AM
michaelh's Avatar
Check this thread from simon3166 when you have a spare 20 minutes or so:
https://www.jaguarforums.com/forum/x...4/#post1721719
Old Apr 13, 2026 | 12:45 PM
Pantera928's Avatar
@michaelh I believe I found the antenna. The other end of the coax cable by the fuse box was tight but I cleaned in anyway.
It looks like the other end of the coax is buried deep down under somewhere. I followed the antenna down as far as I could without taking more stuff apart. Found no connection point yet.
Is that end connection accessed from the trunk or where?
Old Apr 13, 2026 | 02:19 PM
The SLCM is in the boot fuse/relay box behind the battery.
Old Apr 13, 2026 | 05:33 PM
Pantera928's Avatar
Okay, I know where that is in the trunk. Is there another connector at the antenna or is it a one piece unit all the way to the coax connector under the fuse box in trunk?
Flex320
XJ XJ12 ( X305 )
Dec 23, 2022 05:53 AM
jomo
May 27, 2016 10:38 AM
keywasted
Nov 7, 2014 04:05 PM
05XK8cfe
Nov 4, 2014 07:53 PM
Simon.h
Aug 9, 2012 09:48 AM
