Struggling to refit the dipstick tube
Old Feb 16, 2026 | 09:07 AM
pcock111's Avatar
Default Struggling to refit the dipstick tube
Just refitted the LH cam cover on my 2005 x100 XKR. I am struggling to find the hole hidden at the bottom of the engine block, in which to fit the bottom end of the oil dip stick tube. Tried using a camera scope. Anyone have any bright ideas or guidance? thanks
Old Feb 16, 2026 | 09:27 AM
RJ237's Avatar
Unfortunately, the bright idea is too late. If you hadn't removed the dipstick in the first place it would guide the tube into the hole.
Old Feb 16, 2026 | 09:51 AM
dibbit's Avatar
It's not too late to use the dipstick - put it down the tube and see if that helps you find the hole. You will get it back in eventually (that's what she said).
Old Feb 16, 2026 | 09:53 AM
motorcarman's Avatar
The oil filler is ON the left cam cover?
Old Feb 17, 2026 | 01:24 AM
pcock111's Avatar
Thanks guys. Will try a fibre glass electricians threading rod into the hole first as will be able to slide tube over. Failing that, aim camera cable straight into hole and slide tube over iphone usb end of the cable and down into hole. Will let you know how i get on.
LHS when sat in car.
Old Feb 17, 2026 | 04:19 AM
pcock111's Avatar
Please can someone post a photo of the dip stick tube in situ. Many thanks.
Old Feb 17, 2026 | 08:23 AM
You can't see the dipstick hole because it is behind the PAS/AC compressor mount bracket.
Old Feb 17, 2026 | 08:47 AM
Don B's Avatar
In the post at the link below I have a photo of the left side of the engine block showing how the dipstick tube fits in the recess formed by the power steering pump bracket that Bob mentioned. If you can get the end of the tube into that recess, it is usually not too difficult to find the hole by feel:
Dipstick Tube Removal & Reinstallation Tips
Cheers,
Don
Old Feb 17, 2026 | 02:59 PM
pcock111's Avatar
Excellent. Many thanks.Dave.
Old Feb 17, 2026 | 03:30 PM
zray's Avatar
I’m adding this task to my list of things I hope to never have to do.
Z
Old Feb 24, 2026 | 11:31 AM
pcock111's Avatar
Well, I finally succeeded. After several attempts trying to replace the dipstick tube from above, I followed the advice to remove the oil sump pan and thread some curtain wire through the hole from the bottom up. It was actually very straightforward and I would recommend this method to anyone who has had the misfortune of removing the tube without leaving a guide in place. Grinding a notch out of the oil dipstick tube lug was also an excellent piece of advice. Thanks all.
DrkNyte
Apr 15, 2023 08:12 PM
Presence
Aug 28, 2015 06:48 PM
SD96XJ6L
Apr 7, 2015 05:23 PM
Andrew Ardesign
Dec 28, 2013 08:18 PM
GT42R
Jul 11, 2012 10:01 AM
