Trunk Question....
Old Mar 20, 2014 | 02:03 PM
Jon89's Avatar
Default Trunk Question....
With the battery removed from the trunk, can I close the trunk lid and open it again using the trunk release button on the rear of the car?
I'm concerned about not being able to open the trunk lid if I close it with the battery out of the car....
Old Mar 20, 2014 | 02:08 PM
01Silverstone's Avatar
With the battery removed from the car, the trunk release button will not be operable. I believe you should still be able to open it by inserting the key into the lock on the trunk, but just to be safe you may be best off just placing a blanket or something over the trunk latch, preventing the lid from closing. Since the battery is out, no need to worry about interior lights staying on with the trunk not latched.
Old Mar 20, 2014 | 02:15 PM
I'll say 'NO' because the Actuator (item 3) is electric but you should be able to open it with the key because the barrel (item 4) has a mechanical link (item 5) to the Latch (item1).
Pulling on my flame suit now!
Old Mar 20, 2014 | 03:04 PM
RJ237's Avatar
Easy test: Disconnect the battery, then manually close the latch with a screwdriver and try to open it with the key.
Old Mar 20, 2014 | 03:13 PM
RJ237's Avatar
Whenever I work on the car with the battery disconnected, I spring the latch closed and lower the lid just to be safe.
Old Mar 20, 2014 | 03:58 PM
Jon89's Avatar
I'm not going to take any chances. I'll lower the trunk lid tonight but block off the latch with a small plywood board covering the opening so the lid will have to remain open by a couple of inches. Then I'll throw an old blanket over the entire rear of the car to keep out any debris. The battery gets reinstalled tomorrow after my Rustoleum paint on the newly-cleaned battery platform dries overnight....
Old Mar 20, 2014 | 05:04 PM
mike66's Avatar
The locks work mechanically as well as electrically.
Old Mar 20, 2014 | 05:17 PM
Dr. D's Avatar
Howdy Folks:
Just my 2 cents>>Make certain that your key will work before disconnecting the battery. (Only 1 of my 2 black keys will work)
Old Mar 20, 2014 | 09:53 PM
Domingo's Avatar
I'm with Dr. D test the key/keys first! If they work then the mechanical is ok. I did this first before I disconnected the battery on my xk8 for the first time now I don't even think about it.
magmedia
Aug 15, 2019 08:54 PM
bdboyle
Nov 6, 2015 02:07 PM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
magmedia
Oct 8, 2015 03:28 PM
