What shoud I do about P1609 - RESOLVED
Old Mar 22, 2019 | 07:12 PM
rontnm's Avatar
Default What shoud I do about P1609 - RESOLVED
Have a xk8 with a P1609 code,Internal control module CPU to CPU communication error. Wondered what I should do?
Old Mar 22, 2019 | 09:25 PM
car5car's Avatar
Pay some mechanic to diagnose it. If you want to do it yourself, you need to find diagnostic steps and follow them.
Old Mar 23, 2019 | 03:58 AM
JagV8's Avatar
Does the workshop manual not have any info? Normally it lists the possible causes and usually provides detailed ways to test.
Old Mar 23, 2019 | 04:43 AM
frankc's Avatar
Thats not good. The code P1609 is for an internal microprocessor failure. There are two things it can be, a faulty ECM or a shorted to ground wire on ECM wire going from the ECM to the data link connector. The wire is pin 3 (pink) at the 16 way grey connector on the ECM. Make aure that the wire is not shorted to ground. If it's not then disconnect the negative battery cable for 10 minutes, clear the code and see if it comes back.
Just google all the above. I am sure there is lots of info out there that can explain it better than me.
Let us know how you get on wont you?
Old Mar 23, 2019 | 05:51 AM
michaelh's Avatar
Can't see much out there about this: there's a Jaguar TSB about troubleshooting it, but it's essentially saying what frankc has noted above. There's an extra check on the fuel pump relay line, but that may be MY-dependent. What year is the car?
On Gus' site of everything here:
http://www.jagrepair.com/images/TSB/...609%20test.pdf
Good luck
Old Mar 23, 2019 | 06:20 AM
RJ237's Avatar
I would delete the code and see if it comes back.
Old Mar 23, 2019 | 08:56 PM
Don B's Avatar
Hi rontnm,
P1609 could possibly be caused by clumsy insertion of an OBDII scanner plug into the Data Link Connector. Had you had the codes scanned recently?
If the code recurs after clearing it as RJ suggested, both of the wires involved pass through connector EM1, a white 20-way connector in the engine bay near the right hand enclosure. Contamination of that connector or damage to the wiring harness could trigger P1609.
Cheers,
Don
Old Mar 26, 2019 | 06:57 PM
rontnm's Avatar
Smile P1609 error
Found out what it was, the battery was 11 years old and starting to fail. Replaced it an cleared the error and never came back.
Old Mar 27, 2019 | 07:37 AM
JagV8's Avatar
Result!
Old Mar 27, 2019 | 08:10 AM
DavidYau's Avatar
Rontnm,
11 years is very good going for a battery. With this interval for you, it's probably a good time to refresh the battery cables, both positive and negative, and meticulously clean both ends, with grit paper and contact cleaner. Plus the receiving contact terminal surfaces. 5min job.
Ed Videira
May 9, 2017 02:07 PM
guoyesheng
Jul 4, 2011 01:16 PM
stuey
Jan 7, 2010 02:29 PM
