xkr will not start
Old Jul 31, 2019 | 01:34 PM
kevin twc's Avatar
Default xkr will not start
Hi all i was on a thread that was about xk8 not starting or cranking mine is doing the same have taken it to jaguar but the have had it 3 days and i think they don't know what is wrong with it they have
not told me any thing its probable going to cost more than the car is worth 2000 xkr
Old Jul 31, 2019 | 08:51 PM
DavidYau's Avatar
Kevin twc
Sorry to hear that your XKR won't start. Lot's of potential reasons for it - some cheap, some more serious. We'll need a bit more information, ie what noises/conditions for the non-start, car mileage, car service history etc, to help diagnose the problem. Could be bad battery, bad starter, blocked air filter and/or bad MAF, or even no-spark.
But you've said you've sent it to the Jaguar Dealer, so of course their charges will be high. Unfortunately most dealers won't have the staff and/or equipment to deal with issues on a car almost 20 years old now. That's probably the reason for their delay, as the garage has to go back to HQ for the troubleshooting software.
Here's a link to Gus' Jagrepair.com comprehensive DIY walk through for a non- start issue.
JagRepair.com - Jaguar Repair Information Resource
Most forum members would agree that getting a professional garage to work on the car is probably a non-starter (pardon the pun) if you own a X100, as the charges will cost more than the car is worth in the current market.
Good luck and let us know how you get on.
Old Jul 31, 2019 | 10:28 PM
kevin twc's Avatar
Hi David i got the car out and it started but was rough and restricted proformas was on the dash so took it to jaguar who have serviced my car for the last 10 years yes main dealer
so they said it needed a coil pack so got fitted came home all ok then 2 days later it would not start would not crank just made a humming noise at front same as the other post that was on hear
so got rac out they checked all the fuses fine he got under the car and tried the starter with a direct fed i think was not looking and the starter worked so he s jested i take to a rac approved garage
which would be the first time anyone other than jaguar has worked on my car and they could not get it started so it went to jaguar and is still there i think they are waiting to get the soft wear sent
last year it had new fuel pumps fitted it has a new battery on i have done 25 miles since the coil pack was fitted it has 148,000 thousand mills on clock nothing for a engine of this size i have
2 stamped service books it has wanted for nothing had every it ever needed i do not use it as much as i should 300 miles last year i am always in my 1950 mk5 will let you know what happens
Old Aug 1, 2019 | 06:00 AM
frankc's Avatar
Fuel pump or battery or earths.
Just because everything lights up and car cranks over does not mean you do not have a bad earth. I found that out the hard way. If you look under the engine you will see an earthing strap. Take it off. clean everything up with sand/glass paper and try again.
Another thing to try is put the car in Neautral and try again to start up.
Old Aug 1, 2019 | 06:55 AM
kevin twc's Avatar
hi all been done tried it
Old Aug 2, 2019 | 03:53 AM
frankc's Avatar
First mistake. You took it to Jaguar. If its not a part they cannot replace they are not interested. Should have taken it to a proper independent.
Second mistake. You assume they have done what they say, and charged your for. That too I learned the hard way.
Have a read. It might be helpful. Click me to read It might take a while to read it all but may give you some ideas.
Where abouts "UK" are you?
Old Aug 2, 2019 | 04:54 AM
kevin twc's Avatar
hi i am in Newcastle upon Tyne my car has always gone to jaguar for every thing read the post but he did not give a answer starter or what
Old Aug 2, 2019 | 04:57 AM
kevin twc's Avatar
might just scrap it can not be bothered with it
Old Aug 2, 2019 | 05:20 AM
bladerunner919's Avatar
I wish I had the money just to throw a car away because the dealer mechanics (none of which will have any training on the XKR) can't fix it.
Old Aug 2, 2019 | 05:53 AM
frankc's Avatar
Got a picture and a price. I know someone who is looking for one.
Old Aug 2, 2019 | 03:35 PM
kevin twc's Avatar
Old Aug 2, 2019 | 04:09 PM
frankc's Avatar
Now that is a very nice looking car. On a private plate too. Do me a favour next time you go out to the car give the ignition keyhole a spray of WD40 and a gently tap. Sometimes the key hole chip plays up.
I will pass on your details.
Old Aug 3, 2019 | 01:38 AM
XKR-DAY's Avatar
Sounds like your saying the engine will not turn over,
If so it could be starting motor problem or the engine could be locked up some how.
No doubt Jaguar dealer will let you know in time.
Jaguar independent in your area is Alan Carr Jaguar, iv used him now and then.( just google for contact details)
Good luck with getting it sorted and hopefully its a simple fix and not something more serious.
Old Aug 3, 2019 | 03:43 AM
kevin twc's Avatar
Be their to day told them about putting wd40 in lock they said they will on Monday they had 2 days on it and can not fined a fault he has the dash striped down s will see
Old Aug 5, 2019 | 06:23 AM
kevin twc's Avatar
just heard from jaguar £511 for new ignition barrel not guaranteeing it will work
Old Aug 5, 2019 | 08:15 AM
fmertz's Avatar
Ask them for the trouble codes and post them here. Anything to do with the immobilizer? Throwing parts in the hope of fixing things gets expensive. Ask them to demonstrate their reasoning. Show your work!
Best of luck, keep us posted.
Old Aug 6, 2019 | 06:20 AM
frankc's Avatar
That is truly shocking. This is why I do not use dealers. They do not fix things they replace them. Even they its not a guarantee that it will work. If it really is the barrell its more than likely the immobilizer part stuck. Hence spay with electrical cleaner first. Work key in and out a few times. Clean again. Work key 4 or 5 times. Spray it with WD40. Try. If it still does not work then leave it for a while and try again. Not forgetting the occasional light tap to shake it loose if it is stuck.
Old Aug 6, 2019 | 06:34 AM
Jon89's Avatar
I would use powdered graphite rather than electrical contact cleaner. Much better application for the interior lock components....
Old Aug 6, 2019 | 03:51 PM
Gus's Avatar
Gus
The ignition switch and the ignition key cylinder are two different items and are only connected mechanically.
Gus
Old Aug 6, 2019 | 11:38 PM
kevin twc's Avatar
all done and fixed now to sell it
AmberJaguar
Sep 5, 2013 08:14 PM
JeffXType
Oct 27, 2012 08:58 PM
Andy94SC
Mar 19, 2012 04:01 PM
YYC guy
Jan 21, 2012 03:45 PM
BlueJag11
Jan 12, 2011 08:22 AM
