Cloned dealer scan tool
Old Aug 22, 2012 | 04:09 PM
  #101
Six Rotors's Avatar
I have oredered the device referenced in post#32.I will report back when it arrives.
Old Aug 22, 2012 | 04:55 PM
  #102
motorcarman's Avatar
What SDD/IDS DVD version are you going to use?
Are you going to purchase the subscription from Jaguar??
bob gauff
Old Aug 23, 2012 | 07:26 AM
  #103
Six Rotors's Avatar
It is supposed to come with V125,but I will probably try to find V129 or V130.The tool is for my own use so I do not need a subscription--my car is old enough that I doubt any major updates are likely.
Old Aug 23, 2012 | 08:23 AM
  #104
xjrguy's Avatar
Do let us know how it works. Sure had a lot of mixed reviews with clone devices.
Could you post a pic of the rear label when it arrives??
Cheers,
Old Aug 23, 2012 | 09:24 AM
  #105
Six Rotors's Avatar
yes,will do.
Old Aug 25, 2012 | 08:13 AM
  #106
paulik40's Avatar
Default mongoose driver
Originally Posted by Cambo351
No worries, check your email.
hi Cambo351 could you me mongoose 01.02.12 driver
As seller not include driver
Thanks paul
paulik40@hotmail.com
Old Aug 25, 2012 | 08:45 AM
  #107
Cambo's Avatar
Seems a lot of these Mongoose' aren't being supplied with the driver disc?
Paulik check your email.
Old Aug 28, 2012 | 11:48 AM
  #108
Doser's Avatar
Cambo351 send me please old Mongoose JLR driver. I receive this device form seller without CD with any drivers I second day try connect it with my PC, but in device manager allways written Mongoose driver not installed. I think I need old version of driver v01.02.12. Thanks! my e-mail: ravit@inbox.lv
Old Aug 28, 2012 | 12:31 PM
  #109
Cambo's Avatar
I see a pattern forming here... Check your email...
Old Aug 28, 2012 | 01:13 PM
  #110
Cambo's Avatar
Default Functionality will eventually be disabled...
Here's one for the experts!
Connected up to an '03 X100 on the weekend, first I was greeted by the rather disturbing message "SDD software updates have not been performed recently. Functionality will eventually be disabled. Click here to perform updates now."
Click for the full screen view...
The SDD did seem to be working, however I was unable to take any action in resetting the Restraints Module in the X100 (airbag light flashing, code C1981) there were simply no "recommendations". I couldn't find my way in to re-flash the drivers seat module either...
Is this because the car is too old? or because the software hasn't been updated?
I hadn't got round to updating the Mongoose firmware to Pro, would that have anything to do with it?
Old Aug 28, 2012 | 01:39 PM
  #111
xjrguy's Avatar
Cam,
Send me a PM and tell me exactly how you authenticated your SDD. Then I will have an idea how to answer your query. The answer for the rest of the questions is rather long winded, so I'll have to get to that a little later, I have work to do now.
Cheers,
Old Aug 28, 2012 | 11:41 PM
  #112
xjrguy's Avatar
OK Cameron,
At this point the Mongoose firmware really isn't an issue for the things you mentioned. But I do think you should go ahead and do that update at your first opportunity.
As far as the restraints system goes, I don't think SDD will be of much help, other than clearing the code once any fault is found and repaired. The attached bulletin might help more.
Now the seat module is another matter. First, why do you want to flash the seat module? The ONLY time that should be necessary is if you are installing a NEW, blank module. Originally, seat modules for '97 through 2002 were ordered using a software suffix and were programmed by Jaguar Parts before shipping. In 2004 we were given the ability to program those modules in IDS for cars 2004 and later, but we still had to order the programmed module for the older cars. [the basic module is the same part, however, remember that]
In classic right hand not knowing what the left is doing, style, Jaguar Parts got wind WE could program seat modules. Some wise guy said, "If they can do it, we don't have to any more, so we'll only stock & supply blank modules". Not only that, they did away with the equipment and personnel to do the programming! So now, if I get a new module for an older car, I technically can't program it for the car.
Now here's the kicker; the ONLY way we have to program a seat module for a car before 2004, is to put it in a 2004 or later car, program it, and then put it in the earlier car.
DOH! I'm tellin' ya......ya can't make this stuff up!!
File Type: pdf
Old Aug 29, 2012 | 02:57 PM
  #113
Six Rotors's Avatar
Really interesting comment on the seat control module.I sort of thought that if you transferred a module from another vehicle it would have to be regrammed to the receiving vehicle.
Would it be true to say that you could transfer of the other control modules from car to car without reprogramming them?
For example the front body control module?
Old Aug 29, 2012 | 04:40 PM
  #114
xjrguy's Avatar
I tell ya, you guys don't miss a trick..........
I hesitated even offering up that comment, but I did; so here is the follow up warning. NO, this seat module thing is a workaround only of necessity. This DOES NOT mean this sort of thing can be done with any module. In fact, in most cases, if you try to swap modules and program them to the new car like a new module, you will succeed in creating a [possibly expensive] brick. This is particularly true of modules that are in any way related to or involved with OBDII. There are some you can make run the car, but will forever fail govt. required inspection if you have that in your state. There are no blanket answers either. Trying to use a used module is ALWAYS a case by case thing. I've been doing this since before there were modules, and I don't attempt it without researching each and every one, can't possibly remember which will fly, and which won't.
Consider yourself warned.
I'm not trying to be a smarta**, I just don't want someone to get themselves in a pickle because they saw me tell a guy how to get a particular module up and running in a particular car.
Cheers,
Old Aug 30, 2012 | 09:06 AM
  #115
DTSupport's Avatar
In addition to confirm, the upgrade from Mong --> Mongoose Pro will not change the way the software performs, thinks there's an update, or anything like that.
It's strictly for the device. Jag has done some interesting stuff lately in their applications...
Old Sep 4, 2012 | 04:48 PM
  #116
Six Rotors's Avatar
Default Mongoose Arrives
My "Mongoose" arrived today.Pictures are attached.I have loaded the drivers and my laptop recognises the tool.So far I am not able to load the IDS/SSD from the CD sent with the tool.I may have to buy one off ebay.
Attached Thumbnails Cloned dealer scan tool-mg3.jpg   Cloned dealer scan tool-mg2.jpg   Cloned dealer scan tool-mg1.jpg
Old Sep 4, 2012 | 08:36 PM
  #117
xjrguy's Avatar
Thanks for the pics. The label is certainly very similar to the real deal. Notable the label is reversed on the tool, don't know whether it means anything. I have two of the interfaces, and paid full boat for each. Not worth it to me to have to deal with the quirks of the cheaper knock-offs. I also see that yours is put together with cross-point fasteners, both of these here are put together with Torx fasteners.
I don't know what to think about the SDD software, or why it won't load. If you get another disc from eBay, let us know how it goes.
Good luck!
Attached Thumbnails Cloned dealer scan tool-p9042664-.jpg   Cloned dealer scan tool-p9042665-.jpg
Old Sep 5, 2012 | 01:19 AM
  #118
Cambo's Avatar
Six Rotors, which version IDS/SDD did you get that's not working?
Don't pay for a disc mate, the software is free to download directly from JLR
www.diagnosticdelivery.com - /idscentral/ if you've got enought time to download it....
What exactly was the problem with the install? What error messages did you get?
Your operating system has to be in English because the program must be installed in the "Program Files" folder, other languages have other names...
Old Sep 5, 2012 | 10:04 AM
  #119
Cambo's Avatar
Hey anybody read the comments in this thread about VCM's being blocked here
https://www.jaguarforums.com/forum/s...38/#post575883
That doesn't sound good!
Also, poor chap desperately needs some help from someone with an IDS...
Old Sep 5, 2012 | 01:53 PM
  #120
Six Rotors's Avatar
My basic problem is I need to upgrade to Windows XP Pro,and add another 500MB of RAM.
I was able to load the Ford and Mazda IDS software on my laptop with XP Home but not the JLR software.Anybody have a Windows XP Pro with key that they want to sell!
